For sale: Ford flathead 21 stud insert bearing motors (2). Both turn over and should run but not tested. $500 each Early 21 stud flathead motor and trans, extra heads. Stuck - $100 1953 or 1954 265 Buick nailhead with chrome valve covers and early ford trans adapter. Ran when pulled. -SOLD- 1935 -1936 Ford flathead transmission - $100 15" Chrysler Imperial wire wheels, some surface rust but should clean up fine. 5" on 5.5" Chrysler imperial bolt pattern same as early large ford hot rod bolt pattern - $500
