Technical Y block rebuild ideas?
Discussion in 'Traditional Hot Rods' started by oldnuts, Feb 13, 2016.
  1. oldnuts
    oldnuts
    from nebraska
    Anyone have any traditional y block hop up ideas? I'm
    Planning on a traditional y block rebuild with so id like to know what's the best way to make a bit more power off what was available when they were new. To start I've got a 64 292, offy 3x2 with 3 94 carbs and a Mallory dual point distributor. What's the best heads, crank, pistons, bore size, rods ect? Thanks for the help
  2. Blue One
    Blue One
    from Alberta
  3. Alaska Jim
    Alaska Jim
    The offy tri-power manifold is the worst for performance of all the after-market manifolds, according to tests that Ted Eaton has done. It does seem that they are very plentiful though, and other Y-block manifolds seem hard to come by. That being said I have one on my '30 coupe, It has the "wow" factor. I am going to be replacing the eng. this summer with a 2x4 set-up. we will see now that works.----Jim note: the tri-power manifold IS better than the stock 2bbl carb and manifold
    oldnuts likes this.
  4. Jalopy Joker
    Jalopy Joker
  5. Blue One
    Blue One
    from Alberta
    You might like this, I have posted it before, it's the video along with some info on the Y Block that Tim built for my RPU.
  6. sunbeam
    sunbeam
    With a 64 engine you have most of the good stuff except cylinder heads the best heads came out from 57-59.
    oldnuts likes this.
  7. j3harleys
    j3harleys
    DON'T !!! use any Chinese parts
    oldnuts likes this.
  8. My first 2 Model A's had y-blocks, always like those engines, wanna do one more Model A build, look'in for a coupe, like to use a y-block.
    oldnuts likes this.
  9. steinauge
    steinauge
    from 1960
    Best factory heads are the "113" casting number heads. I have used the Offy 3X2 on y blocks before and I much prefer the late factory (B suffix) 4 barrel intake or the factory 2X4 intake .More power and better driveability.John Mummert has any Y speed parts you would want up to and including aluminum heads.
    oldnuts likes this.
  10. jimmy six
    jimmy six
    image.jpeg Y-blocksforever.com. and have some fun. Don't expect earth shattering horse power but 300+ with it's torque will make you smile even without the 57 heads.
    oldnuts likes this.
  11. IronFord
    IronFord
    from NoDak
    oldnuts likes this.
  12. Retro61
    Retro61
    If your planning on a 3 Deuce setup, go with the Edelbrock 573. Ports match the Heads better. Best Intake to run.
    oldnuts likes this.
  13. oldnuts
    oldnuts
    from nebraska
    That's for the help guys.
