thanks to John Mummert and ford-y-block.com Y-BLOCK CASTING NUMBERS ALL BLOCKS HAVE 6015 in the block casting number. This is found on all blocks and is Ford's number for an engine block. Example- EDB 6015 E BLOCK I.D. CODES NOTES CEBY 256-272 cu in Cast in Canada. Export block. Used in Canada, Australia, South Africa CECK 292 cu in Cast in Canada. Export block. Used in Canada, Australia ect EAA 215 cu. in. I-6 1952-53 Ford OHV six cylinder. Increased to 223 in '54. See EBP EAD 317 cu. in. V8 1952-54. Early Lincoln OHV engine. Not interchangeable with Ford. see Lincoln page www.ford-y-block.com EAL 279 cu. in. V8 1954 Ford HD truck. see Lincoln page. EAM 317 cu. in. V8 1954 Ford HD truck. see Lincoln page. www.ford-y-block.com EBJ 341 cu. in. V8 1955. Early Lincoln OHV engine. See Lincoln page. ECU 368 cu. in. V8 1956-57. Early Lincoln OHV engine. See Lincoln page. EBP 223 cu. in. I-6 1954- cars & Lt. trucks. EBR, EBS, EBT in HD trucks EBU 239 cu. in. V8 1954 cars only. Cleveland and Dearborn versions. EBV 239 cu. in. V8 1955 pickup, small cam bearings www.ford-y-block.com EBY 256 cu. in. V8 1954 Mercury ECG 272 cu. in V8 1955 to 57 cars and trucks. Typically Dearborn casting. ECH 292 cu. in. V8 1955 www.ford-y-block.com ECJ 292 cu. in. V8 1955 ECL 292 cu. in. V8 1955 ECK 292 cu. in. V8 1955-56 www.ford-y-block.com EDB 292 cu. in. V8 1957 if cast at Dearborn Foundry. EDB found near distributor and generator B5AE 272 cu in V8 1959 Replacement block for 272. May have been used for marine & fleet PLEASE NOTE: 292 and 312 Blocks were machined from the same castings with the same markings. If the following blocks have EBU main caps it is a 292, if it has ECZ main caps it is a 312. ECZ-A 292-312 cu. in. V8 1956 ECZ 6015 A With EBU main caps =292. ECZ main caps =312 Check crank flange or main caps. ECZ-B 292-312 cu in V8 1956-57 292 or 312 ECZ -C 312 cu. in. V8 1957 ECZ 6015 C. 292 with EBU main caps. EDB-E 292 cu. in V8 1958-59 cars and trucks to April 59. 312 in Mercury B9AE-F 292 cu. in. V8 1959-60 cars and trucks. (312 with ECZ main caps, 1959 & 60 Mercury only) C1AE-R 292 cu. in. V8 1961 cars and trucks www.ford-y-block.com C2AE-C 292 cu. in. V8 1962 cars 62-64 trucks B7ME 312 cu. in. V8 1962? later 312 replacement block. C2AE main webs. Only example seen was a marine engine NOTE: 6015 is Ford's number for an engine block. All blocks have this number. Block identification number generally on side of block above oil filter for blocks cast at Cleveland. Dearborn block I.D. number near distributor and above generator. Most Dearborn blocks used in trucks. No Dearborn blocks after 1957. There were no special truck blocks. Heavy duty trucks with steel cranks used C1AE or C2AE car blocks. Nearly all Dearborn blocks after 1954 were 272's. Most 292 and 312 blocks are from the Cleveland foundry. www.ford-y-block.com
Thanks for posting this. This looks fairly inclusive of all the Y-block stuff. There were so many different ones before and after the MEL & FE blocks were produced. Most folks look at a Y-block and think it is either a 292 or a 312.
