Projects Y BLOCK DYNO DAY
Discussion in 'Traditional Hot Rods' started by Mummert, Aug 12, 2014.
  1. Mummert
    Mummert
    We took the new 331 cu. in. Y block up to the dyno last Tuesday. It was fun and stressful at the same time. Typical dyno day. We played with a few things trying to get it ready to stuff into the 64' Falcon. dyno2lowres.JPG dyno1lowres.JPG
  2. This is making me want to throw the 302 that I'm swapping in my '56 into the garbage. Numbers?
  3. squirrel
    cool beans! A wideband on each cylinder....playing with different intakes...should be a lot learned, right there
    65COMET likes this.
  4. BadgeZ28
    BadgeZ28
    from Oregon
    Don't leave us hanging. What did it make? HP/torque?
  5. Mummert
    Mummert
    Best pull with the dual plain ported manifold 513hp@7100 425tq @5200
    Best pull with the single plain 532hp@7000 438tq @ 5400
    -Brent-, turboroadster, Keep and 10 others like this.
  6. YeeHa!
    65COMET likes this.
  7. fab32
    fab32
    Fantastic numbers for an "obsolete" old war horse. Anything under 3,000 pounds I suggest taking a change of underware with you for the first trip to the drag strip.
    Frank
    kidcampbell71 and slammed like this.
  8. bchctybob
    bchctybob
    Now that's awesome. Any more pics of that fabricated single plane manifold? That's nice work!
    65COMET likes this.
  9. ynottayblock
    ynottayblock
    500+ hp...thats impressive. Can we get some specs on the build and parts used?
  10. Mike VV
    Mike VV
    from SoCal
    Mum -
    Nicely done.
    Mike
  11. Mummert
    Mummert
    1.7 rockers.jpg View attachment 2688724
    1.7 rocker pics
    331ci
    3.84 bore
    3.57 stroke
    13.0 compression
    1.7 rockers
    254 duration .600 lift
    MSD distributor
    Ported Mummert Aluminum heads
    Should be real nice bracket motor. Sounds sweet.
  12. rottenleonard
    rottenleonard
    Turning a Y block 7k is impressive enough, the numbers are just showing off. Thums up! Btw that manifold looks killer.
    dana barlow and loudbang like this.
  13. I really like how you came up with that manifold design which is Y block specific. My hat is off to you.
    don
  14. jerry
    jerry
    WOW! What a set of numbers!
    jerry
  15. Weird A
    Weird A
    I can't wait on manifold info
    Bill
  16. That's great John, well done. What push rods are you using?
  17. Mummert
    Mummert
    The pushrods are Smith Bros. .080" wall chromalloy. , 5/16 ball at the bottom for the TREND tool steel lifters.
  18. falcongeorge
    falcongeorge
    from BC
    Mother of gawd! I understand if you dont wanna give too much detail, but ballparkish, how big is the cam? Guessing 250/260ish??
  19. falcongeorge
    falcongeorge
    from BC
    Oops edit, I see you posted the cam numbers already.
  20. trollst
    trollst
    Seven grand huh? Bet that exhaust note was really impressive, very impressive numbers, I'd love to be there and hear that baby run. Congratulations.
  21. rob lee
    rob lee
    from omaha,ne
    thanks for posting!
  22. Wow, love it when that sort of power is made with the old Y block! I bet some people will look look twice when they see under the hood...
    1.7 rockers and .600 lift, I think you have a secret weapon in there..
  23. Wow, congrats John, You did good !!!
  24. Hot Rod Rodney
    Hot Rod Rodney
    from USA
    Forever changed my opinion of Y-blocks.
    dana barlow likes this.
  25. Cool bananas. Is the bottom end stock?
  26. Mummert
    Mummert
    low res sp.JPG The bottom end is pretty stock..
    -1959 292 block lightened 10 lbs
    -Ford steel truck crank offset ground to Honda rod journal
    -Racetec 10cc dome pistons
    -Molnar 6.125 rods
    -Oil pump stock.
    - Mummert Billet timing set
    -Trend tool steel lifters
    dana barlow and 65COMET like this.
  27. metal man
    metal man
    So it's a 292 truck crank then? I suspect your heads are mostly responsible for the impressive numbers...combined with the matching cam/intake of course.
    I wish I could afford a pair of those heads for mine.
  28. SquirrelTail
    SquirrelTail
    Very impressive I've been dreaming about a 4-71 blown Y-block. Any video of it on the dyno?
  29. Mummert
    Mummert
    No video. Have about a dozen pics and bunch of dyno info. 22 pulls in one day. But definitley worth doing. Dyno's are nothing but good information.
  30. Hey John, do you have any plans to manufacture enough of those 1.7 rockers to sell?
    there is only so much valve lift to be had with the 1.54,s .. its got to be a good thing to keep the cam lobe lift smaller
    and achieve more valve lift by changing rocker arm ratio.
