Technical Y Block dipstick installation question.
Discussion in 'The Hokey Ass Message Board' started by Blue One, Oct 14, 2019.
  1. Blue One
    Blue One
    from Alberta
    For my RPU Y block I’m looking at installing a Lokar dipstick because I don’t have any options for a stock style dipstick.
    It’s a side of the block location and I have the lake headers.
    This Lokar dipstick will work well but I’m wondering if it’s acceptable to bolt the top bracket to a header bolt :confused: :D
    40621A10-CF65-4ECA-8E8F-AB55CD3B6FF9.jpeg 083EE026-0958-486F-8A0D-8C28592B2277.jpeg 30892911-D476-4B3A-9637-EC4CDCFFE59B.jpeg F2898B66-7904-48C0-A799-D8A199E44431.jpeg
  2. I wouldn’t even hesitate, I don’t see a problem there
    Blue One likes this.
  3. jimmy six
    jimmy six
    I'd space it out. Our dirt race engine is this way..
    BTW thanks for using black sp wires. Nothing looks worse on an detailed engine than colored wires...
  4. Blue One
    Blue One
    from Alberta
    I thought I’d maybe replace the one header bolt with a stud and then maybe make a heat isolating spacer of some sort.
  5. tbirddragracer
    tbirddragracer
    A spacer or insulator is not necessary, I have the same dipstick on a 460 Ford with headers. No problem
  6. Blue One
    Blue One
    from Alberta
    So the dipstick doesn’t get hot enough to burn you if you want to check the oil after shutting it down?
  7. Tim
    Tim
    from Raytown Mo
    I thought the dip stick was going to be in one of those bomber seats? ;)
    K13 likes this.
  8. Blue One
    Blue One
    from Alberta
    :p :D:D:D
  9. tbirddragracer
    tbirddragracer
    No hotter than the oil on the stick.
  10. I don’t think it would transfer enough heat to worry about.
  11. Bandit Billy
    Bandit Billy
    That's why they make gloves. :cool: I have the same dip stick on the flathead and fastened to a header bolt. I have never noticed but I have never checked the oil when its hot.
  12. I have the same thing on my roadster, small chevy with lake headers, not an issue and 7000 miles down.
  13. Blue One
    Blue One
    from Alberta
    Of course the bracket attaching to the header bolt wasn’t good enough for me so I made a little stainless steel bracket, removed the header and drilled and tapped the flange to bolt it on. :cool:
    FB8BE1A5-9FA6-41A4-AC37-1A1746CA9640.jpeg 3CE89BBB-5A19-4F94-982A-2ECADEDB545A.jpeg 769AEDAE-D887-4491-9785-3B2BB336581B.jpeg A7BF2766-A5D5-44C6-8DAF-6BE3FF687380.jpeg BFFE1975-91B9-40AD-B495-189C981E7E30.jpeg
    Scumdog likes this.
