Consolidating a few of may adds and considering trades. Chevy 5 lug straight axle. I am not sure what era, but it was recently removed from a driving '34 Chevy sedan. It has hydraulic drum brakes and the bolt pattern is 5 on 4.75". It's really quite nice.$300 In addition I have two 15"x4" Kelsey (canada) steel wheels that would make excellent front runners. Same bolt pattern as the frontend. $125 Nice offenhauser intake manifold for Pontiac #5720. Includes water neck, thermostat, and studs. Nice piece. Will take $150 Extremely nice Holley 4165 Carburetor. 650cfm, spreadbore, double pumper w/ mechanical secondaries. Not far from new by the looks of it. costs $470 new. Will take $225 Pair of fiberglass seat buckets. Nice shape, except that one was cut at one time for clearance for a roll bar (see passenger side). Should be easy fix for somebody with average fiberglassing skills, or leave it alone. Asking $80 for the pair. Willing to ship but buyer pays shipping and the box would probably be pretty large. Have a near new Mallory Dual Point Distributor, Mallory #2548201, dual point. Mechanical advance. $150 firm Chevy 350 crankshaft will need polished or turned. $25 Spectre 14" gauze air filter (same as K&N) $30 Aluminum power steering bracket for SBC w/ LWP. Mounted but not used. $45 Door switched (BWD #S1001) $4 for pair. Flowtech Toobs-2.5" extensions for Block hugger or rams horn manifolds/headers. $35 Voltage reducer- Speedway#64103. $12 (4) new in package rearend u-bolts for 3" axles $20 NOS Lewis 1" Lowering blocks for chevy w/ 1-3/4" wide leaf springs. $35 Moon 15" salt flat discs (1pr) 1 is used one is new $50 for the pair New Milodon tru-roller timing set for BBC #15005. $40 (SOLD) 1965-1966 Chevy full size radiator to shroud spacer $50 1940 Studebaker Splash-pan $75 1940 Studebaker trunk tool-box cover $75 1940 Studebaker pedals $40 New 1960-1963 Chevy C10 driver's side window regulator $35 New Duralast brake pads #280. These were used on many GM vehicles of the 1960's. Mostly full size and pickups. $10 **---** I am interested in trading for the following items: -interesting 17" steering wheel -blowproof bellhousing for SBC -Offenhauser #5415 2x1 Intake for Chevy I6 -Early style Rochester Model BC 1bbl carbs (manual choke versions) -Langdon Chevy I6 exhaust manifolds -17" chevy 6-lug wire wheels (circa mid-late 1930's) -steel/aluminum gas tank/ fuel cell that looks the part -1930's-1940's grille shell and insert -pairs of fenders front/rear from late 1930's-early 1940's cars -gauge panels w/ or w/out gauges -willing to consider other items
