WTF: '55 merc bolt pattern??????????
Discussion in 'The Hokey Ass Message Board' started by anteek, Oct 11, 2012.
  1. anteek
    anteek
    I seem to get in more bs when ASSuming things. A buddy and I split a '55 merc up a few years ago. I kept the rear to use in my T RPU cause I wanted to run wires and wanted the 4.09 gear in it. typical rag from clay country with 3-4" coating the bottom. Blasted and primed the rear,pinion seal and new brakes,good drums. slid it under today,built perches and shock mounts. Went to throw the OLD WW's from the front on and didn't fit. This bitch was as virgin as any car I ever parted out. COULD/ would ford send this bitch out without none matching bolt patterns? found the front end in the inventory and has the same clay BS as the rear had. car was low miles. What bolt pattern should a '55 merc have from the factory? no spare but all 4 rims had the same shade of green. Any info besides i'm scarood?
  2. 4.09 gears in a '55 V8 merc?
    Being a Ford it's most likely either 4.5x5 or 5.5x5.
  3. anteek
    anteek
    V8 overdrive car with 255 y block with 4 bbl.
  4. 38standard
    38standard
    from il.
    So what does the bolt pattern measure?
  5. 65COMET
    65COMET
    5X5,Mercury used that bolt pattern,later Edsel and Lincoln,and Chevy 1/2 ton pickups too. ROY.
  6. Big RWD Buick/Olds/Cad for years had the 5 on 5 pattern as did Chevy and Ford station wagons.
  7. anteek
    anteek
    GUYS OOPS,A BIG OOPS ON MY PART.THE Rear is 5x5,the front is 5x5.5 tho,buddy said they might be '51 merc drums. I mounted the pooch.front doesn't matter.
  8. Mr48chev
    The fronts might be F-100 drums too if not 49/51. Guys did some strange crap to save a nickle back in the 60's when that might have gotten swapped around.
  9. Fenders
    Fenders
    As Rosanne Rosannadanna said: .................. Never mind.
