Would you run this bellhousing?
Discussion in 'The Hokey Ass Message Board' started by chappys4life, Apr 11, 2012.
  1. chappys4life
    chappys4life
    from Austin, TX
    Looking at pickup a bellhousing for my 1953 f100 with a flathead. I am looking at one now and it has had some repairs and unsure if I want it because of the repairs. What worries me the most is that the ear on the bellhousing is the repaired area and is a trans mount. From the pics do you think there is anything unsafe or anything that would make you not run it?
  2. Roger Walling
    Roger Walling
    Not to pretty but it looks like the guy knew what he was doing.
    I would run it and keep an eye on it.
  3. Brad54
    Brad54
    from Atl Ga
    I'd be worried that the localized heat might have shifted the mating surfaces, making it unsquare.
    Input shafts like "square."
    -Brad
  4. I would check the flatness of the housing-engine mating surface. That amount of welding could have warped the piece......lots of residual stresses in that weld area. I would also check to make sure all the bolts and alignment pins mate up correctly.
  5. sickytwisted
    sickytwisted
    I would, but I run flat tires too. :) I kid. No, really, it looks fine to me.
  6. Looks ugly but I don't think you'll have any problems running that behind a flatty
  7. brigrat
    brigrat
    from Wa.St.
    How much is one that's not so ugly, can't be that rare?
  8. slickhale
    slickhale
    from Phoenix
    I'd run it without a second thought
  9. Brad54
    Brad54
    from Atl Ga
    Well, that in itself should tell you something.
    I'd think about a different kind of mounting arrangement if it was a one-year-only deal, and they're all cracked. Sounds like Ford figured there was a problem and changed it.
    -Brad
  10. Have you thought about using yours to cast a new one?
  11. saratoga56
    saratoga56
    from NY
    It should be fine. I have seen worse and functioned fine.
  12. Ghost of ElMirage
    Ghost of ElMirage
    Why not just buy one from someone on the HAMB or the Barn? Ford made millions of em. I'd be worried about how square that thing is after taking that much heat.
  13. I would run it only if I had to and keep looking until I found a better one. In other words go find a better one.
  14. chappys4life
    chappys4life
    from Austin, TX
    It is a one year only deal so semi rare but not sure how hard they are to find as I just started looking
    That is a thought. I also will need the bellhousing modified for a t5 so something to think about.
    This was a bell housing offered after putting a want ad up on the hamb. Have put up some wanted threads on some forums hoping to find one.
    Thanks guys for the advice I will keep it in the back of my mind but more than likely pass and keep looking for a better one.
  15. jack orchard
    jack orchard
    run it until you can replace it. then keep welded one for a spare. good luck....jack
  16. kwoodyh
    kwoodyh
    That was easy!
  17. I'd run it and not give it a second thought. I may check that everything lines up OK and make adjustments as necessary but other than that I would not let it bother me that it is welded.
  18. 19Fordy
    19Fordy
    Would you be able to cast one for him? I have a hunch you are knowledgable
    re: casting.
  19. Engine man
    Engine man
    from Wisconsin
    Was it welded or brazed? It kinda looks like brass in the pictures but colors can be different. If they were prone to breaking in that area, I might worry. Depends on how much abuse you plan to give it.
  20. chappys4life
    chappys4life
    from Austin, TX
    I am not sure what was done.
    My plan is to get a bell housing and have it modified like the y block guys for a t5. It will go behind a mostly stock 8ba. Down the road max I would plan is heads and cam but nothing major.
  21. cffisher
    cffisher
  22. Looks like brass, it was a common way to repair them way back when.
    Unless you put a pretty heavy load behind it it is not likely that you will break it with a flatty even a blown flatty. Its not like you are throwing a 427 cammer infront of it.
  23. If it came out of something running, it should hold up to normal usage. I wonder how it broke in the first place but the repair looks good enough for me.
    Bob
  24. I've seen cast iron bellhousings break in badly crunched stock cars, just curious, not all castings are created equal.
    Bob
