Would it be totally wrong to use a 6cyl in a V8 '57?
Discussion in 'The Hokey Ass Message Board' started by Dog Dish Deluxe, Sep 23, 2012.
  1. Dog Dish Deluxe
    Dog Dish Deluxe
    from MO.
    I think I might just drop the 250 in for a while so I'm still on the road and then i'll rebuild either the 350 or the Pontiac to go back in. I still think the Pontiac in the Chevy would be kool, and honestly the Poncho 350 is a better made engine that the Chevy 350. (Thats coming from a Cehvy guy.)
  2. squirrel
    When I worked at the junkard a few decades ago, we never had a used pontiac engine that we could sell as anything but a core. I dont know why. We sold a lot of Chevy 350s, most of them worked fine.
    The 250 should be a bolt in if you have the right pan on it, and the right mount brackets, and if the V8 was mounted with the modern side mounts and trans mount.
    Then you'll remember why we swap big blocks into old 6 cyl chevys
  3. Don's Hot Rods
    Don's Hot Rods
    from florida
    If you are killing that many sbc engines you are doing something wrong. If they are maintained well and small problems fixed before they turn into big ones they last at least as well as any other motor out there.
    NYC cabs put a zillion miles on them and they are like the Energizer Bunny. If there was ever a testiment to an engine it would be in a NY cab ! :)
    You can put a 6 in there, but you aren't going to like it very much.
    Don
  4. 296 V8
    296 V8
    from Nor~Cal
    With all that going on the last thing id do is a swap ….. bolt in another sbc = no changing nothing or hunting parts ………………………………...........
    If you must do a swap put in a nice flathead :rolleyes:
  5. patrod
    patrod
    from idaho
    6 cyl, ok, big block, yea, pontiac, that would be wrong!
  6. Dog Dish Deluxe
    Dog Dish Deluxe
    from MO.
    The SBC was supposed to be my "Temporary" engine for like the next 20 years until I got around to figuring out how to put a 401 Nailhead in there. (And figuring out how to fund it) Guess I'll just run the 6 for a while, even if it does suck squirrel nuts. I admit I do too many motor swaps but some sick twisted part of me actually likes it I think.
  7. Kerrynzl
    Kerrynzl
    Drop a 6.5 GM Diesel into it.
    Just make sure the cooling system is up to it!
  8. Deuces
    Deuces
    from Michigan
    I have no comment!!...:rolleyes:
  9. your car ,,.... with prices the way they are going ... less gas is great in my book ... well thats if you drive your car everyday or alot . If its parked 98 % of the time ...then go big block .
  10. Rusty Heaps
    Rusty Heaps
    Blasphemy!:D
  11. Dumb idea and ubnless you are "building" small blocks and they don't last long maybe you should find another "builder" to pay for the build.
    If you can't make 150-200k out of a rebuilt small block and run the guts out of it everyday there is something seriously wrong and a 6 cylinder is not going to cure it.
    I am just sayin'.
  12. I grew up driving the old sixes and I have no fond memories of those engines.the distributors wore out and wobbled around and there was a constant battle with carb/ignition/ blowby and oil useage issues.....
    Dont use a 235 in that Chevy, they are not a better engine....If anything they have more associated problems across the board than any smallblocks did.
    Also any claims of increased mileage was dreaming as well.....they are definitely a step backwards....
    did your SB engines you lost get a rebuild before installing or just a used engine swapped in?
    Get a basic rebuild kit from Northern Auto parts and build yourself a decent SBC motor,it will definitely be better and more powerful and even cheaper to rebuild than an old stovebolt boat anchor.....
  13. propwash
    propwash
    from Las Vegas
    don't rebuild the engine yourself. It's obvious you're not very good at driving and I'm sure your engine building skills are equally inadequate. Engines should last longer than tires....30k miles on a CRATE motor indicates that YOUR driving habits are at fault. The only other item I noticed is that you indicated that your radiator is already in front of the support (the six-cylinder position). If you have no shroud and are using stock fan, then perhaps you're just not watching your gauges?
    Bus passes are quite cheap these days, turn that '57 over to someone that can make it work.
    dj
  14. Blue One
    Blue One
    from Alberta
    Your problems with the SBC will not go away by swapping in a 6. The problem is most likely in your driving habits and or your maintenance routine.
    As most others have said the SBC is a good long living engine, I had a 305 in a 86 Pontiac that ran perfect from new till I sold the car with 685,000 Kilometers on it.
    In all that time the engine ,700 R4 and rear end were never opened up and were just given regular maintenance.
    You are doing something wrong.
  15. customrod48
    customrod48
    about as wrong as swapping a Ford Flatty for a SBC in a shoebox Ford...............
  16. forget the engine problems, i'm thinking you have a tranny problem. are you aware there is more than first gear?:eek::D
  17. Deuces
    Deuces
    from Michigan
    I think he's better off finding another hobby...
  18. robber
    robber
    from Colorado
    :eek:Yes... It would be wrong; totally wrong! Don't... please don't...just DON'T DO IT!:mad: You are kidding, aren't you:confused: Its like putting a slant six in a Hemi car... its sacrilegious!:rolleyes:
  19. oldtom69
    oldtom69
    from grandin nd
    This is kind of a guess, but what are you using right now for motor mounts??If you are still using the 57 front mounts,and then mounting the th350 at the tail shaft housing I would bet you are taking out main bearings!Thats a long flexible span between mounts.
  20. oldtom69
    oldtom69
    from grandin nd
    P.S. pretty sure the Pontiac starter will be right where your steering box is?
  21. junkyardjeff
    junkyardjeff
    It looks like you have the same luck with those motors as I do since I could never get too many miles out of one even with proper maintenance and now with the 235 that is in my 37 p/u. Put a Olds rocket in it and you will look back,a 59 371 with a 4 bbl off the same year 394 is a good combination but they are a little wide but worth the effort. I had that same motor in a 53 88 2 door sedan that would out run sbc powered vehicles.
  22. Rusty O'Toole
    Rusty O'Toole
    Why am I the only one not surprised by the number of motors you have used up? It squares with my experience of Chev v8s. One summer I swapped out 2 Target Master 350s for customers, both blew in a big way, one had 30,000 miles on it the other 20,000.
    I had a neighbor who was a big Chev fan, one time he had a 72 Chev pickup and I had a 72 Dodge, he swapped out about 5 engines in 3 years, I was still on the original engine in my Dodge. But I did have to change a $3 ballast resistor.
    You might have better luck with a 292 truck 6 cylinder. In stock form they have similar power to a 307 or 305 but a few changes like a cam, intake and exhaust can really wake them up. They are a tough long lasting engine even in hard working trucks so should last you a long time.
  23. jcmarz
    jcmarz
    from Chino, Ca
    Now you got it wrong. A mouse motor is the best improvement one can do to a Ford.:D
  24. U-235
    U-235
    "Would that be totally weird since its originally a V8"
    Yes...
  25. slowmotion
    slowmotion
    SBC's only getting 20-30K miles lifespan? Sumpin' ain't right, in either the operator, builder, or materials, dept. All those offering up different swaps, really? In a '57 of all things? I'm all for being different, but sometimes perfection isn't to be eph'd with. JMO. A reliable, stout, long living, sbc ain't rocket science, or overly expensive.
  26. lukey
    lukey
    If it puts it on the road so u can enjoy it, go with a six! It will stand out better than a sbc also!
  27. 73super
    73super
    Heck .. I'm putting one in a '55 Buick.. tell me THAT won't piss people off. But it'll be a daily driver and will definitely be a first.. I can always swap it out later if not happy with it, but that's the bottom line.. do what makes you happy! Worth a shot.
  28. There is a guy locally that has a nice '57 with original paint that looks great and he used a V6 and a 5 speed tranny,,every thing else looks totally original,,nice car. HRP
  29. Truckedup
    Truckedup
    Yup,Chevy V-8's only last 30,000 miles,everyone knows that.And you head it on the HAMB so it must be true.:rolleyes:
  30. belair
    belair
    Since you're determined to keep on being stupid (your word), put a 194 in it. At least you won't be able to go fast enough to wreck the body.
