Working with brass
Discussion in 'The Hokey Ass Message Board' started by Mindover, Oct 21, 2011.
  1. Mindover
    Mindover
    from England
    For anyone interested in metalshaping, I will show how to shape a brass windscreen (windshield) frame for a Deuce.
    In my day to day business I do a fair amount of work with brass but most of it is for vintage cars (Bentley SS Sunbeam Talbot and the like) Below is a Rad shell I hand made for an SS100.
    The other day a friend of mine turned up with some brass extrusion that he wanted bent to shape a rear windscreen (windshield) trim for his '32 soft top. I thought this might be of interest to some folk on here so...
    My friend gave me the Brass extrusion and he also gave me a cardboard pattern of the shape he wanted the screen to be. The first thing I did was to cut a piece of plate to give me the shape of one end of the screen. It would have been better to have a former that was the complete shape but this was all the plate I had to hand and I had to get it back to him the next day.
  2. Mindover
    Mindover
    from England
    It takes a fair amount of heat to form the brass, It needs to be a dull red, any hotter and it will crack too much cooler and it will crack.
    You have to form it without excess heat or force.
    David
  3. F&J
    F&J
    Thanks for posting the temp color range.
    How do you join the frame, with silver solder, or?
  4. Mindover
    Mindover
    from England
    No I welded it. I do a lot of welding of brass (the rad shell above is made from six sections welded together) and this meant that I could blend the joint so that it was invisible.
    First I veed the joint so that I could be sure I had welded it through.
    David
  5. chrisntx
    chrisntx
    from Texas .
    You mean you BRAZED it
  6. Mindover
    Mindover
    from England
    No I WELDED it brazing is joining parts using an alloy with a lower melting point, the parent metal is not melted when you braze. You can braze aluminium - you use a lower melting point alloy.(aluminium (not brass) The process I use is welding I melt the parent metal and I use a filler material with a similar make up.
    David
  7. damagedduck
    damagedduck
    from Greeley Co
  8. metal man
    metal man
    Nice work. I'm curious,did you use an arc welding process,or flame?
  9. Mindover
    Mindover
    from England
    Sorry I should have said - It was gas welded as was the Radiator shell.
    Not the neatest of welds but it was going to be ground and filed off so I was more concerned with making sure it was fully joined.
    David
  10. oj
    oj
    Where did the extruded brass come from? That looks like some handy stuff!
    Thanks, oj
  11. Off to the chromer, I like it !!!
    Yes where's the extrusion from?
    Nice job on the radiator shell.
  12. toolman1967
    toolman1967
    Nice job, you are very talented. Great Rad shell!
  13. Mindover
    Mindover
    from England
    Thanks for the comments. I have made well over 200 of the SS100 rad shells all hand beaten. Lots of other shells too.
    The extrusion came from Paul Beck (Vintage Supplies) here in the UK. I am sure it must be available in the USA and other parts of the world though.
    Here is a link to the Vintage Supplies website - lots of stuff for vintage cars and several different extrusions.
    http://www.vintagesupplies.com/
    David
  14. nefareous
    nefareous
    from maryland
    Nice work, but I`m curious as to "200 shells for an SS100"..? I did not think there were that many surviving cars, or were they going to be used for replica Jags ? I needed one a while back, but could not find one... so I used a cut-down Allis Chalmers tractor grill.
  15. Mindover
    Mindover
    from England
    Some of the shells I have made have been for original SS100s (the one in the photo above was) others have been for replicas, many are for a very good kit car called the Suffolk Sports this is based on XJ6 running gear and a 'glass body & box section chassis.
    Below is a photo of an SS100 replica that I built the body for a little while ago.
    This car is a very accurate replica of an SS100, based on a modified saloon chassis and running gear. The salons post war had almost the same engine and suspension as the SS100 did pre war. Its a lot of work to build one of these but even a good replica is worth quite a bit. The kit Suffolk Sports costs about fifty thousand GBP when done I believe.
    I would like to see what your SS100 looks like. Is it an original?. If you still want a shell you know where to get one now:).
    David
  16. nefareous
    nefareous
    from maryland
    David, Damn you are quite the craftsman. Mine is just a P.O.S. f`glass replica that I bought on eBay for a couple hundred.
  17. Mindover
    Mindover
    from England
    Here is the trim vee'd or chamfered ready to weld,...
    here is the welded joint again...
    And once it was welded and cleaned up...
    David
  18. Mindover
    Mindover
    from England
    It looks like a lot of fun though!.:cool:
    David
  19. cavemag
    cavemag
    That rad shell is gorgeous.
  20. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Amazing! I always wondered how brass was handled. Any pics of building a grille shell? How do you meld 6 pieces together and form them?
  21. Mindover
    Mindover
    from England
    Well having made over two hundred of the SS100 shells alone I have a lot of photos. I will post some build photos as and when I get time if people think it is HAMB friendly enough. I want to show the rest of the 'screen trim job first though.
    David
  22. Beautiful metalwork is always HAMB friendly David. Thanks for posting.
  23. niceguyede
    niceguyede
    from dallas
    x2.
  24. 19Fordy
    19Fordy
    Mindover: You are a true cratftsman. Nice to see that high quality work still being done.
  25. Dude, next Baleigh contest, you need to make a detailed post on making the shells, then take home a sweet piece of their metal working equipment.
  26. koolkemp
    koolkemp
    Wow very nice work ! Incredible workmanship ,I would love to see some pics of the SS replica posted earlier that you built the body for as well...I think we could all learn something from your skills!!
  27. BRENT
    BRENT
    WOW David thats some amazing work, very clean.
  28. harley man
    harley man
  29. Great work - as usual - actually thats an understatement - unbelievable work as usual.
    Stop doing paid work & get back to your Deuce chassis........One day I'll be back to see it in person
  30. Beautiful as always David. Post away on the grill shell although not strickly HAMB material there would be a ton of info that could easily be applied to something that was.
