Technical wix
Discussion in 'The Hokey Ass Message Board' started by sunbeam, Nov 22, 2024.
  1. I wonder!!!
    What if one bought a Fram and a NAPA and opened them ones self what one would see.
    Ben
    Sharpone, 29A-V8 and Unkl Ian like this.
  2. poco
    poco
    from oklahoma
    My dad had trucks, always used fram filters no problem, i have owned several cars and pickup in me 89 years have not used any thing but fram filters, never had a problem, all you have to do is keep your oil changed regular.
    Sharpone, 29A-V8, KiWinUS and 4 others like this.
  3. tubman
    tubman
    It's been done. Do a search on this forum. As I remember, the differences were easy to see.
    Sharpone, mad mikey and Unkl Ian like this.
  4. Perhaps I should re word that. What if someone on the forum replicated the NAPA test. And videoed it.
    Sharpone and Unkl Ian like this.
  5. But that one was "Made in USA". :eek:
    FRAM is a multi-national corporation with manufacturing facilities in multiple countries.
    Sharpone, firstinsteele and 2OLD2FAST like this.
  6. You guys might be surprised if you really dug into the story, who makes what filter. The same company that makes Fram, also makes AC Delco Filters. First Brands Group owns several filter brands including Fram, Champion Laboratories, and Lubrifiner. I’ve been in this industry way too long to believe each of these companies are making filters of their own design. There is rebranding happening. I’m not an oil filter engineer and when Joe Blow on the internet (said with a Hank Hill accent) cuts apart a filter and starts motherfucking it’s construction, I believe they are full of shit. Let the engineers figure out what is best for each application. The best thing you can do is service the damn filter regularly. Oh, and Fleetgard filters were mentioned, they are a damn fine filter, Fleetgard is owned by Cummins Engine Company. In 34 years, I’ve only seen 1 filter cause an engine problem. It was on an International Maxxforce 9 engine, it caused a low flow problem that didn’t damage the engine, but caused a low Injector Control Pressure issue and by extension a low power complaint. The filter, was an OEM International Navistar filter. We chased this problem for over 2 weeks as a warranty issue in 2012.
    finn, Sharpone, tractorguy and 2 others like this.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    You've never cut a filter open looking for shiney stuff ? Did you have any idea what to look for in filter construction ? If not , it's pretty much an exercise in futility .
    29A-V8 likes this.
  8. Bought a case of WIX filters this past spring, all have Made in the U.S.A on them IMG_2950.JPG
  9. I have to admit that I’ve never wondered where my filters were made at
    So far, so good
    bob b., Sharpone, oldsmobum and 6 others like this.
  10. Where the heck is the " over their head " emoji?
    Ben
  11. JD Miller
    JD Miller
    fu·til·i·ty
    /fyo͞oˈtilədē/
    noun
    noun: futility
    pointlessness or uselessness.
    "the horror and futility of war"
    futility
    noun
    fu·til·i·ty fyü-ˈti-lə-tē
    plural futilities
    Synonyms of futility
    1
    : the quality or state of being futile : uselessness
    His speech focused on the futility of violence.
    2
    : a useless act or gesture
    the futilities of debate for its own sake—
    W. A. White
    Unkl Ian likes this.
  12. 1971BB427
    1971BB427
    from Oregon
    I buy my filters by the case also, and discovered Fleetguard filters made by Cummins. Their LF692 is a 1.5 quart filter that fits Chevy V8's and I paid $11 each for them last purchase. High quality American made, with huge capacity. Might not be good for low slung engines as they hang below the pan, but my cars aren't tail draggers, so no issue.
    dan c, bchctybob, 38Chevy454 and 6 others like this.
  13. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Until you learn that the six grand you spent on your dream engine, was wasted on false belief.:oops:
  14. JD Miller
    JD Miller
    You be Futil,,,, Weren't me , must-a been you :rolleyes::eek::D
  15. '29 Gizmo
    '29 Gizmo
    from UK
    Worse than China......
  16. Kerrynzl
    Kerrynzl
    Don't do that if you are a barstool engineer, or get quality control advice from your hairdresser.
    They base their conclusions on looks , appearance, and hearsay .
    The biggest complaint I hear about Fram is the "cheap" cardboard end caps on the filter element.
    But if you play around with adhesives [like I do] you'd realize this actually is a feature.
    Try gluing incompatible materials in a heat cycle environment.
    From Fram
  17. Jack E/NJ
    Jack E/NJ
    from NJ
    > > The biggest complaint I hear about Fram is the "cheap" cardboard end caps on the filter element. > >
    Next thing you know, they'll use toilet paper for filter elements. :D
    Just Gary and seb fontana like this.
  18. jimmy six
    jimmy six
    And your oil will be much cleaner!
    Sharpone and 29A-V8 like this.
  19. Budget36
    Budget36
    lol. My dad used TP in his 235. Used to piss my mom off if he used the last roll.
  20. tubman
    tubman
    My old man used to be a rep for Frantz Filters (AKA toilet paper filters). They were bypass filters, and the toilet paper elements provided an extremely fine filter, which had the added advantage of absorbing and holding a lot of moisture. Adding one to a vehicle that had an existing "Full Flow" filter provided a "Belt and Suspenders" approach that is still used today in semi trucks and other severe-duty applications.
    Used properly, they are an excellent addition to most vehicles.
    Sharpone, jimmy six, 29A-V8 and 2 others like this.
  21. Roothawg
    Roothawg
    Mobil 1 filters.
    https://www.mobil.com/en/lubricants...tended-performance-oil-filter-limted-warranty
    Sharpone, Joe Blow and mad mikey like this.
  22. I think the Mobil 1 is also a fine filter. With that said, I am out on this filter war thread. Its DEAD.
  23. Budget36
    Budget36
    lol. I use the M1 or STP, whichever is bundle with the M1 oil I use.
    I used to use Fram, until the internet “scare”. But I never had an issue with one.
    Sharpone likes this.
  24. Budget36
    Budget36
    Back in HS, I used Hastings oil filters, they had a long one and a normal one. But both had a nut on the bottom of the filter, so much easier than a filter wrench
    bchctybob and Sharpone like this.
  25. 2OLD2FAST
    2OLD2FAST
    from illinois
    I remember those sheet metal " nuts" twisting/ tearing off if you breathed on them the wrong way , also some putz's used them to overtighten the filters .
  26. 2OLD2FAST
    2OLD2FAST
    from illinois
    Your sarcasm eludes me ..
  27. 1946caddy
    1946caddy
    from washington
    Box probably was made in the USA :rolleyes:
  28. Budget36
    Budget36
    I recall the nuts being nuts, not sheet metal ones, but it has been 45 years or so;)
  29. Joe Blow
    Joe Blow
    Every year I have a hot rod calendar hanging up in the shop. Never could remember to flip the page from month to month......now I just use new filter threads to remind me and it's pretty damn accurate. Thanks fellas.
    NoSurf, Fortunateson, twenty8 and 6 others like this.
  30. Beanscoot
    Beanscoot
    Stuff is made all over the world nowadays.
    Just a few weeks ago my Rockauto order came in, and lo and behold I lucked out and got the "good" gasket from the Faroe Islands!
    Fortunateson, Sharpone and Budget36 like this.
