Hot Rods Wiring
Discussion in 'The Hokey Ass Message Board' started by sdluck, Feb 25, 2020.
  1. sdluck
    sdluck
    Those of you that have wired your hot rod,whose kit did you use and how did it work? I have a fiberglass model A and I am rebuilding it? I need some recommendation. Thank you
  2. upspirate
    upspirate
    I've used painless for my first,ez-wire for my second. I preferred the painless and their instructions.
    Both were in steel vehicles. In glass, make sure you run good grounds
    lothiandon1940 likes this.
  3. V8 Bob
    V8 Bob
    My choice is Ron Francis. I like his design, where wires are routed to the fuse panel vs from. RF offers more accessories and information, along with several panel kits. One more item I would recommend for a glass body is their ground wire kits that I also use on steel bodies. No, not cheap, just very high quality with great customer support!
  4. On Model A's, I just wire it up myself. Like upspirate said, "make sure you run good grounds". My last couple of builds I just rewired them without a kit. The last kit that I used was on my '46, it was a Rebel Wire, Inc. kit. I will use them again, the next time I use a kit. Quality stuff, good helpful people plus they are an Alliance Vendor!
    clem and bct like this.
  5. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Rebel Wire, Alliance vendor. Great customer service. Im no pro, and I'm about to install my 4th kit from them
  6. x3 Rebel
    JeffB2 likes this.
  7. okiewelder
    okiewelder
    from central Ok
    I used Rebel on my last and will use another on in my next rewire!!
    JeffB2 likes this.
  8. I have used several Enos Black Boxes. They are gone but someone else is making the black box. I think they are an excellent board. Use google if no one else posts it. I have used Rebel kits just for the good quality wire, but not used their fuse holders which are pretty generic. The Rebel kits would not at all be a bad choice.
  9. woodiewagon46
    woodiewagon46
    from New York
    I have a Ron Francis kit in my Wescots '32. As others have pointed out, with a glass car grounding is an issue, ground everything!!
  10. Bandit Billy
    Bandit Billy
    I start with 3 of these, one up front for lights, horns, Fans (heavenforbid), etc. Another under the dash for the gauges and accessories and finally one in back for tail lights, fuel tank sender, intank pump, reverse lights, plate marker, etc.
    They come with a plastic cover to make them somewhat weathertight. Run a #4 or larger to a good frame ground to the big lug on either side.
    I do this for steel cars, I would definitely do it for a glass car. Then design the stating/charging circuit through a disconnect switch, a 150 amp breaker and a ford style solenoid.
    Fuse panel use depends on the car you built. If you have a ton of relays (PW, fuel pump, Seat Heaters, Fans, Lights, etc) I'd go with Coach Controls.
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    abe lugo and LAROKE like this.
  12. Another Rebel Wire fan here. I bought mine "second hand" from BlueOne and they were still super helpful with answering my questions.
    abe lugo likes this.
  13. trollst
    trollst
    American autowire, you don't need support on the hamb, directions are crystal clear, and the kit is complete. Don't need anything else, its all in the box.
    chargin03 and clem like this.
  14. 3 cars done with Rebel and I didn't have any questions to ask. But I did buy some cloth covered wire to make my own for the '28.
  15. I will bet their directions aren't crystal clear for things like wiring an ignition with a push starter. There are always things that can come up that might need answering and having someone actually answer the phone when you call and walk you though it is priceless.
    LAROKE likes this.
  16. I've used painless in the past and was happy with the kit and the result. Rebel looks good (I've never used one) and the support certainly seems to be there. I'd use one. I'm wiring a 50 Ford right now from scratch, which I've done before but I wouldn't recommend doing that without some experience behind you.
    As stated above, in a 'glass car grounding is mega important, almost like a separate wiring system in itself.
  17. Hard to beat Painless and EZ for quality, price, overall value. Both assume a level of knowledge about wiring theory, not super detailed cook book instructions but not too bad even for a novice. Main advice I can give for any wiring job is pay close attention to grounding, 'glas or steel. Grounding problems are 99% of what you run into.
    upspirate likes this.
  18. dirt t
    dirt t
    1. HAMB Old Farts' Club
    Buy a name brand kit. The ebay none brand is very hard to read the wire identifying name. Unless it's printed on a white or light color wire it's very hard to read. I wired my neighbors pick up with a wire harness (non branded) it was a bitch
  19. Rebel. Look at the large thread they have going on here.
  20. BJR
    BJR
    I used a Kwik Wire kit for my 49. Great instructions and everything worked first try. They have a harness with a ground kit just for fiberglass cars.
  21. MCjim
    MCjim
    from soCal
    Made my own...based on a '70's Harley bagger wiring schematic... and many of the components, Bosch relays, circuit breakers and connectors.
  22. David Gersic
    David Gersic
    from DeKalb, IL
    Painless. Worked great, no problems. Easy, even.
  23. clem
    clem
    I used an American Autowire. Went with the most accessories possible.
    Great kit, no issues, but total over kill for a basic deuce coupe.
    We considered doing it from scratch, but as I am a farmer, living out of town, I didn’t want to be making multiple trips to town for something I missed. By buying a kit Everything is there, no wasted time.
  24. clem
    clem
    We actually did this, worked it out for ourselves !
    Plus tail lights which are different here as indicators must be separate from tail lights.
    I guess a lot depends on you individual level of capability.
    I’ve heard of a guy who was an regular electrician, but wouldn’t touch the wiring on his own car .
    My son wanted to be an auto electrician as a teenager, never pursued it, yet wired most of my car with the kit.
  25. chargin03
    chargin03
    American Auto Wire on my A. Very good instructions.
  26. Rebel is currently helping me with a custom project and I have not bought anything from them yet, but I’m going to. Customer service is alive and well at Rebel.
    1stGrumpy likes this.
  27. reagen
    reagen
    Ron Francis , so easy.
  28. L. Eckart
    L. Eckart
    As an old electrician friend advised me; do one wire at a time and then test to make sure it is working . Most all the kits mentioned previously are good and I have used Ron Francis, Painless, Speedway, and EZ Wire but I plan to try the Rebel Kit on the next one. The last one was a Painless panel I purchased second hand without any wire. I called Painless to see if I could purchase the wire only but was told they couldn't sell it to me without a panel. However they did send me the instructions for the panel I had and I then used their color coding/wire guage to buy the wire from an on-line supply house. Wouldn't recommend that for the first timer though. As stated previously: GROUNDS ARE CRITICAL.
    upspirate and LAROKE like this.
