Hot Rods Wiring
Discussion in 'The Hokey Ass Message Board' started by Bigchuck, Sep 10, 2017.
  1. Bigchuck
    Bigchuck
    from Austin, TX
    I am rewiring a "57 Chevy and looking for. the mushroom shaped bulb contact for single filament instrument bulb sockets. OK if it has a wire attached. Old wire is way too brittle to splice See picture to see what I am looking for. The bulb sockets themselves are fine.
  2. You can either unsolder the original ones and re-use them, or you can buy new ones (someone here will know of a U.S. Supplier).
    I have re-used many of these, just remember to install the spring before soldering.
  3. Marcosmadness
    Marcosmadness
    Your local auto parts store (NAPA) should have these. They are called "pig tails". One wire for single filament bulbs and 2 wires for dual filament.
    Hnstray and olscrounger like this.
  4. 56premiere
    56premiere
    you can use the part off a pop rivet to make your own. 1/8 usually works
    Hnstray likes this.
  5. manyolcars
    manyolcars
    I often strip off about 1/8" of the insulation, flare the copper strands and add a nice fat drop of solder to make the contact
    Hnstray likes this.
  6. 325w
    325w
    from texas
    How many you need?
  7. Bigchuck
    Bigchuck
    from Austin, TX
    Found them! Rhode Island Wiring Service Inc.
  8. Bigchuck
    Bigchuck
    from Austin, TX
    NAPA never has what I need. I gave up on them.
  9. d2_willys
    d2_willys
    from Kansas
    Check with YnZ wiring in Redlands, Ca. They have all kinds of stuff for wiring. I believe I bought some of those terminals there many years ago.
