Wiring question
Discussion in 'The Hokey Ass Message Board' started by johnod, Mar 6, 2013.
  1. johnod
    johnod
    I'm going to do some rewiring/tidying in the car, and am going to use some multi wire connectors, at various points to allow easy future removal of things.
    The question is can grounds and hot wires go in the same connectors, or should they be in seperate connectors?
    Thanks
  2. Ebbsspeed
    Ebbsspeed
    Yes, the manufacturers do it all the time.
  3. Kevinsrodshop
    Kevinsrodshop
    Same is fine as long as the connector is capable of handling the current flow that you plan on running.
  4. johnod
    johnod
    OK Thanks.
    Connectors should be fine , are Packard OEM style connectors, sized for different gauge wires.
    Nothing is a major load dash, seats, few other odds and ends.
  5. jcapps
    jcapps
    from SoCal
    That's fine
