wiring kit for a hotrod
Discussion in 'The Hokey Ass Message Board' started by bobo, Jan 6, 2011.
  1. Mudgy
    Mudgy
    this is the one thing I notice at car shows that will make or break the look of a vehicle - the wiring. Maybe 'coz I am an Auto Electrician, this is what I look at, maybe a painter and a trimmer look at finish and interiors?
    I have seen so many nice looking cars ruined by dodgy looking harnesses whacked back in the engine bay, and other places. Just a shame.
    For my 37 Dodge I will make my own harness for everything.
    Crimped and soldered terminals (then a bit of shrink tube over the terminal) is the way to go - holds up in heavy diesels and race cars (vibration prone applications)
  2. The37Kid
    The37Kid
    Mudgy, from a safety standpoint is it safer to run wires inside the boxed chassis or attached to the outside were thay can be ripped out in the case of a fire?
  3. Mudgy
    Mudgy
    1. if you got a fire, ripping wires from a chassis rail will not be your 1st priority.
    Access to a battery master switch will be what you want - plus an extinguisher handy!!
    If you run chassis harness thru the rails, you need to mount it at the exit points securely with insulated saddles, and tha part that runs inside I recommend to be double insulated (tape wires first, then slip convoluted tubing over that).
    ALWAYS fuse circuits, some can be from a common fuse.
    When I wired some Formula 5000 cars, and Formula Holdens, the guys told me fuses weren't necessary! WTF????
    Because they were mechanics, I had to argue the point.
    So we ended up with the compromise of all power going to the dash, engine ECM to be supplied via a fusible link from the starter motor point, I won in the end. Also made a dyno harness that plugged in to the car on race day. It would lay over the engine, replacing the entire engine harness (connected to the bathtub via a military plug). This way, the heat was lost, but not the entire race day. Also one part did 3 jobs. The team had no idea something so simple could be such a great asset when needed.
  4. Doc.
    Doc.
    We have used the American Autowire cloth kit and we're very pleased with it.
    Doc.
  5. bobo
    bobo
    from Florida
    Thanks for all the replys, I'm going with the American Autowire kit.
  6. Steves32
    Steves32
    from So Cal
    I have a Highway 22 in my roadster. Very nice & great tech department. Donny's the guy to talk to.
  7. A.P. Photography
    A.P. Photography
    I will be ordering the AA Highway 15 kit for the 55 soon.
  8. thebronc4019
    thebronc4019
    from New Jersey
    I used an American Autowire kit in one of my cars. Great kit, easy to install and 8 years of service without a hitch.
  9. nico32
    nico32
    from fdl, wi
    x2 for Street Rod Electrics as well
  10. herbet99
    herbet99
    from Central NJ
    For you Rebel Kit guys.. any suggestion for an on-line source of connectors? and what type? Sealed or Unsealed? I'm thinking type 56 connectors would be sufficient.
    Thanks.
  11. BulldawgMusclecars
    BulldawgMusclecars
    Del City has everything you would want, and then some.
  12. Johnny1290
    Johnny1290
    Del city is the place to get the good stuff. Aside from that, I see good connectors at home depot, believe it or not, I think made taiwan, which is about as good as I can find.
    The do wierd stuff with the country of origin, stuff made in the us can get shipped to taiwwan and back here so its made in taiwan and all sorts of wierd stuff
    that's my 2 cents, get connectors that *aren't* made in china. It takes longer to find them, but worth it.
    If I were ordereing from del city I'd get the connectors without any cheap plastic insulation.
    I crimp, solder, and heat shrink
    the autoparts stores are all real expensive for connectors if you ask me
    oh and get the good heatshrink from del city, the kind with the glue inside, it's the best and impossible to find locally , at least for me
  13. 1gearhead
    1gearhead
    I have installed many different wire harness kits in my shop over the years and I would rate American Wireworks and Ron Francis at the top of the list for quality. Every thing else falls short. Cannot stress enough, that you get what you pay for in this area.
  14. herbet99
    herbet99
    from Central NJ
    Thanks Bulldawg and Johnny1290... I wouldn't have thought to try Home Depot.
  15. Johnny1290
    Johnny1290
    Yeah go figure. At home depot they're gardner bender or thomas and betts, so at least they're name brand instead of the generic china crap you get at most autoparts stores. Plus they're cheaper I think.
    I just got one of those little cases from harbor freight, it has a flip lid on either side and little compartments in it. I keep all my connectors separated in there, along with anything else small and easily lost. Works for me anyway.
  16. micky69
    micky69
    from Ohio
    The American Autowire Hwy 22 kit is a excellent poduct. I have used American Autowire the last 20 years I have been building musclcars and rods with their regular resto wire harness also. Francis would be my second choice.
  17. FritzTownFord
    FritzTownFord
    No one mentioned Painless. Other than the price, what are your issues with Painless? I've used a couple of their harnesses with no problems and their kits had everything I needed to do the job.
    Please be adult, CONSTRUCTIVE criticism?
  18. Tacson
    Tacson
    Hot Rod Primer and Steve do you all still rate the AAW kit tops? I would be a first time wiring on a 56 F100. I saw a good price on a Kwik Wire. I met the owners and talked with them a while as we were both vendors at a show in Knoxville. Rebel is about 100 miles from me. I would like to go with one of the 3 as they are American made. AAW Highway series 15 or 22 would be my first choice because it is so complete. Just looking for miles on the road feedback for the AAW.
  19. ago
    ago
    from pgh. pa.
    I like AAW because the wires terminate at the fuse box. You can decide wich wires to use.
    Ago
  20. 34toddster
    34toddster
    from Missouri
    I like Affordable Street Rods wiring kit simple and very well built along with the US made parts and great phone support, I'd say there are many good kits out there, I would never buy a kit that has both ends terminated, A friend bought a Painless for a LS motor what a hugh mess, enough wire for 2 cars.
  21. AHotRod
    AHotRod
    American AutoWire ..... is #1
    That's all I'll use and I've done numerous wiring jobs.
  22. nunattax
    nunattax
    looking for feedback on PAINLESS PERFORMANCE 12 CIRCUIT PICKUP HARNESS NON GM COLUMN COMMENTS GOOD OR BAD PLEASE
  23. Cooder2
    Cooder2
    from up yours
    I've installed several Painless harnesses. Also used their switches, relays and parts. Had no problems and the labeling on the wires is very helpful. Although I am a Ford guy, I recommend the generic GM harness, it seems to be the most user friendly.
  24. nunattax
    nunattax
    good ive just bought one, not ready to use it yet
  25. Don's Hot Rods
    Don's Hot Rods
    from florida
    I used a Rebel 9 + 3 kit in my 27 and it is a good, functional kit. I am pleased with it. However, my Son has an American Autowire kit in his rpu and IMO it really is the best kit out there in a lot of ways.........certainly more money, but better. Just one benefit is the fuse panel being separate from the wires, and you just plug in one at a time and only what you need.
    As for the cloth wrapped AA kit being expensive, yep, it is, but the process they use is very labor intensive to wrap each wire with the cloth. I guess if a guy were doing a truly traditional car and wanted the wiring to look old timey, it would be worth the extra money.
    Don
  26. Sumfuncomet
    Sumfuncomet
    I've used painless and Ron Francis kits before. I prefer Ron's kits. As a former Navy Electronics Tech I was most impressed with the Francis product. Very clear and well written instructions.....pick up the phone and call them, you get a real person right then!
  27. Sumfuncomet
    Sumfuncomet
    Oh I should add that if you are doing fuel injected or extrinsic trans, Ron Francis has the expertise in that area also.
  28. 2002p51
    2002p51
    First car I ever wired was the one in my avatar. I used an American Autowire kit and it was very easy. Six years on the road now with 0 electrical glitches.
    Last year I rewired our '47 Mercury with another American Autowire kit and everything worked the first time.
    Like others have said you get everything you need and the instructions and wiring diagrams are great. If you've never wired a car before this is a good way to go.
    When it was time to rewire a '62 Falcon I used a Rebel wire kit and really liked it. You do need to buy switches, etc., separately which is a big reason why it costs less, but I like the way everything was pre-bundled, i.e. rear harness, under hood harness, engine harness, dash, etc.
    The wires in both kits are way long enough to reach everywhere and I have tons left over.
    I've never used a Painless kit but have heard some guys say that Painless should include a fire extinguisher with every kit they sell! :D
  29. jcapps
    jcapps
    from SoCal
    AAW is the best most inclusive kit on the market. When you compare the others AAW is hands down the better choice. It comes complete with headlight switch, dimmer and ignition switch. Includes all the connectors and is easily mountable. I liked installing them so much I just became a dealer for them
  30. zeke1270
    zeke1270
    from Alberta
    American Autowire for me, like them better everytime I use the kit.
