Technical Window regulator
Discussion in 'The Hokey Ass Message Board' started by Sean hurl, Jul 14, 2015.
  1. Sean hurl
    Sean hurl
    I have a 56 88 2 door sedan that needs a left front regulator... Would any of the other gm cars this year or close fit this car of mine
    Thank you
    Sean
  2. looks like Olds/Buick Special 54-56....sometimes the riveted in gear set can be removed from a four and put back in....seems that gear set is all that wears out along with the shaft teeth...
  3. mgtstumpy
    mgtstumpy
    A quick fix, swap the gear for rear 1/4 winder & make a pattern for teeth on arm. MIG weld the teeth & file to shape. You might want to heat treat them for piece of mind?
