i have them on my new car. what is up ?i 'm using the wilson hub too.i'm using the GM buick drum.does the drum go on the inside or outside of the studs on the hub ?
Wilsons hubs go on the outside of the drum. You can put them on the inside, but then you have to fit the hub to register to the drum. No that big of deal if you have a big enough lathe. Look at wilsons web site, I talks about drilling the drums to match the hub. I really like the drilled effect. I might have to do that to mine.
Hub on outside,big washer plate on inside. Long bolts from the inside act as the studs and squeeze it together. Through a tack weld on the bolt heads to prevent backing out .
