Technical WILLYS Front Axle Info needed
Discussion in 'Traditional Hot Rods' started by The37Kid, Dec 8, 2017.
  1. The37Kid
    The37Kid
    Are there "Early' and "Late" Willys stock factory front axles? Did a search and nothing came up. Photos and dimensions would be great, I may need one in the future. Bob
  2. NORSON
    NORSON
    '33 to '36 is narrower than the '37 to '41. Four lugs up into the later body. don't know the cut off year.
    Norm
  3. earlymopar
    earlymopar
    Do you mean "Willys"?
    - EM
  4. elgringo71
    elgringo71
    Four lugs up to the 1939 model 48. The one that looks like a 1937-38 Willys not the 1939 Willys Overland. (Some call the Overland a Sharknose and it has heart shaped headlight lenses )
  5. Here is a model I built of the '39 Willys.
    1940Willys, Fordors and elgringo71 like this.
  6. The37Kid
    The37Kid
    Thanks, Corrected that shouldn't post late at night.o_O Bob
  7. The37Kid
    The37Kid
    Thanks, hope some photos get posted, I think the early one has a nicer forged area king pin to spring pad.
    Bob
  8. DDDenny
    I say "Willis" because I've been told by older drag racers that's how it's pronounced.
    Chucky and verde742 like this.
  9. 1934coupe
    1934coupe
    If memory serves me right 33-36 have around 3/4" kingpins and 39 and up have 7/8" kingpins.
    Pat
  10. Legend is that is the way that J. North pronounced it too.
    deathrowdave, verde742 and rfraze like this.
  11. The37Kid
    The37Kid
    Someone has to have a photo of one!
    Bob
  12. DDDenny
    More than 90 years after John North Willys came to Toledo, there is confusion about how to pronounce his name.
    “I talked to many people, now deceased, including his private secretary, and all said emphatically that he pronounced it `Willis,' said Ron Szymanski, local Jeep historian. “I can attest to the fact that Willys' relatives all say `Willis.'”
    http://www.toledoblade.com/local/20...is-name-Willis-local-Jeep-historian-says.html
    Chucky, verde742 and rfraze like this.
  13. 37, 38 has an inch more drop than a 41,42. not sure the cut off so 39, 40 ??? Some one will chime in with real facts.
  14. NORSON
    NORSON
    King pin c/c '33 - 43 inches '40 - 48 inches
    Spring center bolt c/c '33 - 22 1/4 inches '40 - 27 inches
  15. Mine will always be a Willies!!
  16. The37Kid
    The37Kid
    OK! Thank you NORSON! That sandblasted one in front is what I'm looking for, there should be one out there since I don't see any Willys 77 drag cars using one. Next question is what do the rear spring mounts look like for this axle. Bob[​IMG]
  17. They use the same spring shackles and nuts as Willys Jeeps. Can get exactly what you need at a Jeep dealer.
  18. 1933-1935 shackles are different than 1936. 1936 are like early Jeep and use a U bolt with bushing nuts, the earlier ones are Tryon type shackles. They use a tapered pin in the frame and the spring with a bolt through the center to hold pressure. Look down a couple of posts, I found a pic on my phone
  19. I didn't know that. My coupe is a '36.
  20. I guess I should ask the obvious question; what car are you wanting this axle for? Your questions are pretty random, do you have a specific Willys in mind?
  21. @The37Kid
    Well I found a pic on my phone and cropped it. Hope this helps
    The37Kid and elgringo71 like this.
  22. The37Kid
    The37Kid
    ^^^^^^^^^^^^ Thanks! Bob
  23. earlymopar
    earlymopar
    Interesting. Like many others, I'm constantly running across people who pronounce it the way the family did or does. - EM
  24. The37Kid
    The37Kid
    It was used on a Vintage race car I hope to restore. Bob
  25. Got it!
  26. zeph4057k
    zeph4057k
    no its not, the original car maker, john willys, said it was pronounced "willies".
  27. fsteddie
    fsteddie
    from Pa
    I suppose this debate will go on forever, I always called them 'Willys', but when I was a much younger man (maybe 17) I heard 'KS Pittman' (famous gasser fame) call them 'Willis' cars. That took me back because it was the first time I heard it pronounced that way. I then later in life remember seeing a Willys factory advertisement and the man speaking in the commercial called them 'Willis'. DDDenny may be right. I kinda like the sound of Willis myself, and maybe partial because of the time I got to spend hanging around KS for a few summers.
  28. steveo3377
    steveo3377
    Anyone know what thread is on 33-36 Willys spindle for castle nut that holds hub?Not having any luck using 5/8 fine, is it some odd thread?
  29. The37Kid
    The37Kid
    If one of these '33-'36 axles turns up I'm still looking for one. Bob
  30. Pete Eastwood
    Pete Eastwood
    from california
    Bob, I know where there are a couple of them.
