Technical Will this Radiator work? 1932 Ford
Discussion in 'The Hokey Ass Message Board' started by Duke, Aug 23, 2021.
  1. Duke
    Duke
    C027BA6A-53ED-4F74-85C9-46453CBECF7F.jpeg 9F4F2F90-A6BA-4E63-A2FA-4AB1C424CED3.jpeg 04D3FBAF-0328-42BB-B30B-8A139EBDD8B9.jpeg 8E93B1BB-34C2-49C8-AC59-443AAF18CEE0.jpeg 04D3FBAF-0328-42BB-B30B-8A139EBDD8B9.jpeg I have this old heavy copper/brass radiator. Do you think it would be OK in a 1932 Ford if I added some mounting legs and 32 style shell mounts?
  2. 19Eddy30
    19Eddy30
    from VA
    You will have to see if a 32 shell will fit,
    If it does then add the mounting tabs
    Model As will work but top tank is a little different . There are measurements/ dimensions online for a stock 32 radiators
  3. goldmountain
    goldmountain
    Looks like it would be worth a try. The sides should be made of steel and are easy to weld to.
  4. Duke
    Duke
    I was thinking I could add a little and it might work
