Hot Rods Will my Hemi with cast pistons Handel a 671 blower
Discussion in 'The Hokey Ass Message Board' started by Jesse Duke, May 2, 2019.
  1. Jesse Duke
    Jesse Duke
    loudbang and Deuces like this.
  2. sunbeam
    sunbeam
    The 9 to 1 is a little iffy with out big boost and staying out of detonation I would say yes. With your set up you are not going to see high rpm. That is the piston killer. I will get flack for that last statement.https://www.jegs.com/tech-articles/superchargers.html
    porknbeaner, loudbang and Jesse Duke like this.
  3. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    9:00 to 1 compression ratio if I'm reading that right - that's on the edge.
    Is this a street driver only of strip ?
    Street - for a while as long as you are not really hammering/ revving it all the time....
    Strip - probably not for long.....
    Those blowers make a lot of power and can really blow stuff up - especially cast anything.
    Forged Pistons would be a lot better.
    My opinion
    Deuces, mgtstumpy and Jesse Duke like this.
  4. Jesse Duke
    Jesse Duke
  5. Jesse Duke
    Jesse Duke
  6. This must be an afterthought?
    If you keep the max boost low is should be ok.
    But by doing that you’ll be making blower noises and dragging the parasitic loss just from driving the blower.
    Get forged pistons
    mgtstumpy likes this.
  7. lippy
    lippy
    from Ks
    Why would anyone take the chance on destroying an engine for the price of a set of pistons? Lippy
  8. squirrel
    put a bigger cam in it, and you should be ok, as long as you don't get too wild with boost.
    Montana1 and mgtstumpy like this.
  9. I suppose why he asked the question.
    Ive got a hair up my ass to put a 671 on a bone stock SBC 307 :D with stock flat top pistons and the shitty stock heads. Those 307 boat anchors are almost free and not 10gs though.
    Sounds sweet don’t it?
  10. dreracecar
    dreracecar
    from so-cal
    Would not care about to much about the pistons as much as the boost, general rule is that you should o-ring the cyl's with anything over 9# of boost. and in reality using a non stripped blower (and a little loose for street) @ 3# will set you way back in the seat.
    saltracer219 likes this.
  11. Jack E/NJ
    Jack E/NJ
    from NJ
    As is from Joe's Hemorrhoid shop will also set you way back in the seat plenty enough. Jack E/NJ
  12. Boryca
    Boryca
    from Detroit
    I don't put cast pistons in anything I want to last very long anymore... Forged are always worth the money, in my opinion; especially if there's a power-adder or high compression involved.
  13. Jesse Duke
    Jesse Duke
    I was going to buy the engine .. it it was a good price we worked out a deal I did some research and wanted to reach out for some other opinions
  14. 41rodderz
    41rodderz
    from Oregon
    There you go. Smart to ask ?'s before you buy.
  15. mgtstumpy
    mgtstumpy
    Would you double key way the crankshaft and harmonic balancer?
  16. OLDSMAN
    OLDSMAN
    I wouldn't put cast pistons in anything anymore especially in blown applications. I had an experience with the engine in my convertible that makes me a believer in forged pistons. When I built the engine the only kit could buy had forged pistons, the engine always detonated and got worse the longer the engine was ran. Short story I had an engine knock when I got home from the lead sleds in Salina 3 years ago. Engine siezed a piston on the wrist pin. A cast piston would have been destroyed. A new piston , and rings ran a hone in the cylinder, engine is good as new. I did get the cause of the detonation fixed as well
  17. 73RR
    73RR
    In addition to the high 9:1 on a cast piston you also need to be cautious about the skinny connecting rods, and head gaskets. Lots-o-places for things to go wrong.
  18. porknbeaner
    porknbeaner
    No you won't. As long as the boost is not silly high (I have an opinion on low boost but I'll keep it to my self) and you don't rev it 'til it comes a apart you should be fine.
    @sunbeam back in the '90s I had a friend at MOPAR Performance that said stuff that you could take to the bank and nearly everyone on this board would scoff at. I put some of the things he said to the test.
    He's retired now he was a grey beard back then and he knew his chit.
    Montana1 likes this.
