The drivers side door on my '52 Special (small body Buick) is rusted out along the bottom, inner panel too. The inner panel is a bigger concern than the outer, since the outer is just sheet steel, but the inner is stamped. Is this the same as a Chevy inner door panel? Any info would be appreciated.
post some pics of the inner and i will investigate send me a pm with your tel number , i would like to look at some other parts to see if they fit the ems guy
Well, a Buick door is completely different from a Chevy, it's certainly not going to work without a bunch of modification, if the length is even right. You're saying you can't make a box that roughly copies the other side? That's all it is, is a box, with curved corners.
