Will a '54 Pontiac Starchief hood fit on a '54 Chevy?
Discussion in 'The Hokey Ass Message Board' started by Westside Lefty, Jan 14, 2009.
  1. Westside Lefty
    Westside Lefty
    from Venice
    Well.... any thoughts?
  2. plodge55aqua
    plodge55aqua
    from Alberta
    Is the pontiac a straight 8? if so.. it might not..
  3. Gerg
    Gerg
    from what i have heard no the front end is longer on the pontiac then on a rockstar
  4. rustypipes
    rustypipes
    from san jose
    Ive seen the opposite done 54 chevy front sheet metal clip on a pontiac body
  5. Nekronomicon
    Nekronomicon
  6. Westside Lefty
    Westside Lefty
    from Venice
    Thanks for pissin' in my cheerios fellas. Haha
  7. its called a Candian Pontiac...but as greg said the Pontiac is 6" longer in the nose !
  8. you could modify one?
  9. Flop
    Flop
    you can make anything fit anything olds!!
  10. It doesn't fit. Pontiacs have a 4 1/2 inch longer wheelbase, all in the front. You can't modify it, either, because the sides are angled different the entire length.
    I suppose if you took it apart (they're two pieces) you could cut it down so it would fit, then you'd have to weld something in where the center trim was.
    or you could just look a little harder for a Chevy hood. It shouldn't be that hard to find - and a '53 would also fit, although it may not match the grille lip.
  11. plodge55aqua
    plodge55aqua
    from Alberta
    Canadian Pontiacs?? oh wait.. we got those.. :D..
  12. Westside Lefty
    Westside Lefty
    from Venice
    THe idea is to run the Pontiac hood trim on my Chevy. I guess that's not going to work.
  13. pasadenahotrod
    pasadenahotrod
    from Texas
    I know a 57 Pontiac hood fits a 57 Chevy so I guess the wheelbase difference there is in the body?!
  14. Little Wing
    Little Wing
    from Northeast
    Do a hood skin graph ?? Pontiac skin onto Chevy hood frame ?
    You could trim the back where it would be to long and that might work ?
  15. Westside Lefty
    Westside Lefty
    from Venice
    That's a damn good idea! Now I just need to find the Pontiac hood. Anyone?:)
  16. fryguy
    fryguy
    This may sound offbase and not trying to sound like a smart ass. Could you just take the Poncho trim itself and mount it to your chevy hood? Or am I missing something?
  17. Westside Lefty
    Westside Lefty
    from Venice
    From what I understand, it's actually inset into the hood.
  18. 54 is entirely different than the later '55 up body style.
  19. Flop
    Flop
    there is about a half inch step in the hood where the trim sits.
    in 50 the overall shape of the hood is different too from chev to poncho
  20. Yes it is inset.....the easiest thing would be to mount the Poncho trim to your hood and then take some round stock and place it along side the trim, weld it in place and mold it in. If you want to fool around and use stock Poncho trim you'll have to cut it down to fit your hood length or if you get crafty you can use the shorter Canadian hood trim!
    I have a bone stock '54 Ponch and can tell you that the frontend is way longer than the Chevy of the same year. Another thing to look at is the way the trim ends at the front.....'54 Ponch trim ends under an emblem and basicly needs the emblem to finish it off. Look at the other trim from '49 up to '54.
    I don't blame ya for looking at that big hood trim.....I love the looks of it also....and it really shines when polished. So much shine that it can blind ya in sunlight.
  21. Canadian pontiac hood would work. Same wheelbase as a chev up here. Pat
