Will a 5.60 tire fit on a 6" rim?
Discussion in 'The Hokey Ass Message Board' started by Dice, Mar 31, 2008.
  1. Dice
    Dice
    from Marion, TX
    I plan on changing to a thinner rim in the future, but need to know if the 5.60/15 tire will work on a 6" rim. Any pics would be great.
  2. touchdowntodd
    touchdowntodd
  3. touchdowntodd
    touchdowntodd
    oh you wanted pics...
    my old tires were 5.60s on 15x6 wheels
  4. crackerbilly
    crackerbilly
    Sure it'll fit fine, may have to put them on a machine with a good bead blaster. the 5.60 means the over all width is 5.6 inches wide at the sidewall breaking point, with an actual tread width of 4 to 4 1/2 inches. it will have a small balloon look to it, but will wurk fine if u don't run too low a air pressure. ron-on, crackerbilly
  5. beaulieu
    beaulieu
    from So Cal
    its a VW bug tire , made for a 4 inch rim
    its not really a safe option if you ask me.....
  6. DirtyThirty
    DirtyThirty
    from nowhere...
    It WILL fit...it WILL be a pain in the ass to mount, and it will look "balloony"...
    A slimmer rim would be best, but...
  7. VNCduke
    VNCduke
    from Washougal
    Just dont try "drifting" it too hard after you get them mounted
  8. Sam F.
    Sam F.
    a 5.20 will fit on a 7" rim!
  9. streetfreakmustang
    streetfreakmustang
    from Ohio
    I don't like the look of it. Better to stick with a 4-5" rim max. The sidewall on a 5.60 on a 6" rim "balloon" out too much for my discriminating taste but hey it's your car.
  10. fab32
    fab32
    Be sure to keep tabs on the air pressure if you do it. Too little air, a little to sharp a turn..............................well, you get the idea.:eek:
    Frank
  11. noclubjoe
    noclubjoe
    i have had 5.60s with 6 inch radirs on the front of my model A for many miles and never had a problem.
  12. stretch 1320
    stretch 1320
    What the hell is a rim? Are ya'll putting bicycle rims on your cars? Wow! I'd like to see that!
  13. VNCduke
    VNCduke
    from Washougal
    It seems when i hear people call wheels "rims" its usually some dumbass kid from my school referring to some kind of gay flashy wheels. for example "you should put some rims on that" or "dude you dont even have rims on your caddy yet". uggh
  14. BadLuck
    BadLuck
    Yup! The lowrider days..skating on 13x7's with 520's...those were the days!:D
  15. DIRTYBIRD
    DIRTYBIRD
    ha ha ha....scraped rim edges covered with gold o
    push on welt to cover it. Gotta love them 5.20's
  16. beaulieu
    beaulieu
    from So Cal
    a modern radial tire is 165x15 , used on VWs...
  17. Dice
    Dice
    from Marion, TX
    Thanks for the info. The tires should arrive tomorrow, so I'll see how it works out. I have an extra pair of some oddball wheels that are 5" wide just in case. Too bad they're a different style. I'll get this stuff turned into a matching set eventually.
