Technical Will a 14" wheel clear this Speedway brake kit?
Discussion in 'The Hokey Ass Message Board' started by Fordor Ron, Mar 18, 2014.
  1. I have this brake kit from Speedway on my 32 Fordor but the car is in pieces right now so I can't check without bolting it all back up.
    Will a 14" Wheel Vintiques Smoothie wheel clear? Found a tire I like but it only comes in 14" so I'm thinking of switching.
    Thanks in advance...
    -Ron
  2. t-rod
    t-rod
    I've got that same caliper and bracket on my roadster with 14" E.T. wheels. Not a lot of clearance, but enough.
  3. hayu
    hayu
    call speedway and ask them.
  4. T-rod... Thanks for the heads up. I think I'll be OK as well but just wanted to ask.
    I will call Speedway tomorrow when they open. I new somebody on here would know though.
  5. Yowza...
  6. It'll work Ron, done it many times.
    Depending on caliper, ya may have to grind a little off the caliper depending which ya use
    It's tight but , go for it.
  7. doinbad
    doinbad
    from celina tn
    i had same brake kit on a 29 roadster it cleared with 14 chevy factory steel wheels
  8. Thanks for the replies guys...
