Widening a 65 Chevy Stepside Bed
Discussion in 'The Hokey Ass Message Board' started by lakeroadster, Mar 16, 2009.
  1. lakeroadster
    lakeroadster
    from *
    It is a LMC roll pan that I modified to fit between the fenders. Also had to modify the fenders a bit too.
  2. NuckinFutz
    NuckinFutz
    from GA
    You fixed the main reason I hate stepside trucks. It looks great! You have one of 3 stepside trucks I've ever liked. I can't wait to see it painted.
  3. looks perfect... you captured what a bad ass truck should look like!!!
  4. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    How about narrowing the cab on another truck and see how that improves the looks. My first new pick up was a 67 which had much better proportions than 60-66's, that's why I bought it.
  5. Deadbird
    Deadbird
    Nice looking truck. I like the subtle mod on the bed a lot. You really fixed a design flaw there.
    What paint are you using for the orange? I have a few rust issues on my C10 that I want to fix, but I just can't bring myself to repaint the truck. Your orange looks like it could be a match.
  6. lakeroadster
    lakeroadster
    from *
  7. Deadbird
    Deadbird
    That's too cool! Never would have guessed Rustoleum. Looks like I'll be tackling that rust repair after all. Thanks man!
    Nice touch with the 3rd brake light. I just noticed that.
  8. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Turned out nice. Well done!
  9. lakeroadster
    lakeroadster
    from *
    Thanks for the encouraging words fellas. This is my "Good Enough" truck, just having fun with the build, taking it whatever direction it seems to go.
    Here's the current status, as of Nov 2012:
  10. lakeroadster
    lakeroadster
    from *
    I installed some modified bed side trim across the back of the cab at the two tone paint break line.
    Pretty subtle, not very noticeable in the photos below, but it visually ties the custom cab b-pillar trim panels together.
    I also mocked up some side trim on the truck, just to get a visual of how it would look. I am still 'on the fence" as to if I want the trim at all.
    Comments?
    I personally like the short spear look vs. the long stock spear.
  11. Deadbird
    Deadbird
    Looking good.
  12. 64C20CrewCab
    64C20CrewCab
    I saw your rig on one of the other forums a while back but did not realize you widened the bed!!! NICE job and thanks for sharing the info. I'm in the middle of a long fleet to long step swap along with a rearend swap on my 64 C20 Crew... Dreading the narrowing and was seeking options here. Thought bout this awhile back and seeing it done puts the nail in the coffin. Thanks!!!
  13. Hackerbilt
    Hackerbilt
    Man! I missed this thread so I'm really glad it got brought back up!
    AWESOME truck...but more so...an awesome EYE for the details that can take a project to the next level.
    Great job.
  14. lakeroadster
    lakeroadster
    from *
    Thanks for the accolades guys.
    Here's a link to the build thread for my truck: http://talk.classicparts.com/showthread.php?t=13928
    Just as a heads up I wanted to share that I swapped out my CPP 5" rear drop coils for some CPP 4" Heavy Duty drop coils. Much better ride. The 5" were made from smaller coil spring wire, with less coils resulting in a spring rate that was way to spongy.
    4" Heavy Duty Drop Springs are on the left, CPP P/N 603-4HD, 5" Drop Springs are on the right, CPP P/N 603-5
    A little more rake.. which I prefer, and now I can use it to haul stuff again that weighs more than a few hundred pounds.
  15. 64C20CrewCab
    64C20CrewCab
    Your rig has a nice stance!
    I had the same issue with my rig. My crew cab was to heavy on either so we bagged it with a c-notch. I use it as a truck as well as cruise it.
  16. lomonte
    lomonte
    from Indep., MO
    Cool Ol truck! I meant to say thanks, I used your shock mount design on my 70. Great writeups and info. A loss to the 67-72 board. Thanks again.
  17. Barn Find
    Barn Find
    from Missouri
    Very nice work!
  18. lakeroadster
    lakeroadster
    from *
    Glad the shock mounts worked for ya!
  19. 64C20CrewCab
    64C20CrewCab
    I followed your lead on this with my long stepside. It's coming along nicely. Thanks again for sharing your info!!!
    lakeroadster likes this.
  20. lakeroadster
    lakeroadster
    from *
    Mocking up some stock side trim but not in the stock configuration. Balances out the white two tone on the cab by adding some white, and some bling, to the bed.
  21. lakeroadster
    lakeroadster
    from *
    Built some gravel guards for my ole Orange Crate.
    Here are some photos:
    Same Faux Patina process that I used on the rest of the truck
    As viewed from under the truck
    Exterior Photos
    And a comparison photo showing an OEM style guard:
