why is my engine being dumb
Discussion in 'The Hokey Ass Message Board' started by mr. h, May 1, 2012.
  1. ok i have a 302 out of a 74 maverick bored 60 over (yeah i know its too much, i didnt build it) its got a cam and 351 heads. alumunim radiator with a shroud and big fan. so i drove her to austin from ft worth no issues, temp stays at 180. got a little hot in traffic in austin and drove back fine. Now since ive been back it has started spraying water out of the overflow tube on the radiator. I replaced the thermostat with a 160 degree and put a new 20lb radiator cap on. what could cause this? im never getting over 200 degrees on the gauge and ive checked the sending unit and its working fine. so why in the hell am i spraying water out now. i have no water in the oil either.
  2. fordor41
    fordor41
    head gasket? Timing moved?
  3. studefreak
    studefreak
    Better check it for combustion gasses in the cooling system
  4. moefuzz
    moefuzz
    head gasket
  5. Steve Ray
    Steve Ray
    Had the same problem in an OT project. Head gasket.
  6. El Caballo
    El Caballo
    You might want to have the heads checked as well; I had the same kind of thing with my Suburban and there was a cracked head.
  7. Bored out too far!
  8. Boryca
    Boryca
    from Detroit
    .060 isn't too bad on a 302 in my opinion.
    On to the question: 20 lb cap seems excessive, but are you sure you're not just over full? After all, the overflow is there for a reason, water expands as it heats up.
  9. KoolKat-57
    KoolKat-57
    from Dublin, OH
    If you are running straight water, that could be part of your problem.
    More likely head gasket.
  10. Compression test, and cooling system pressure test, combustion gas in cooling system.
    That will take about an hour for both and give you proof one way or the other.
    Hope its just a head gasket and not a 60 over problem.
    You could also run the engine with the cap off and look for bubbles, if its not a very bad leak ithat might not be easy to spot.
  11. Yeah, that's the thing about engines. They're dumb as a rock.
  12. Mr48chev
    Does the cooling system have a puke can on it aka coolant recovery can? If it doesn't make sure that coolant level is down a couple of inches in the top tank of the radiator cold so the coolant has room to expand. Then if that doesn't do it you are off to have the thing pressure tested and checked for combustion gasses in the cooling system as others suggested.
  13. mashed
    mashed
    from 4077th
    You're eating Nut n Honey Crunch, aren't you?
  14. I just went through this on my 51 Ford Thanks to Wilson Rad shop. It was the wrong style Rad Cap. The early Ford cap neck is 1" deep and the new ones for pressuer caps is only 3/4" deep. A new style cap just does not seat and stop the water from pushing out the over flow. Just go check that first. There is a cap that will fix it or you can change the cap reciever to a late style.
    The Wizzard
  15. MATACONCEPTS
    MATACONCEPTS
    Blown Head Gasket Symtoms: Choc Milk like oil or White smoke out the tailpipe.
  16. DrJ
    DrJ
    READ THIS!
    Pull the plugs and check the color.
    The insulators should be tan to brown.
    If most are tan but one or two are snow white new looking then that's coolant leaking past a head gasket "cleaning" them.
    If that's ok then your over heating in traffic problem is retarded timing at idle/low RPM.
    Fix the retarded timing at low RPM/overheating in traffic problem by moving your vacuum advance source to manifold vacuum instead of timed or venturi vacuum.
    As to the puking coolant, put on a coolant recovery system like ALL cars have now.
    I run a 180º stat and a 7 lb recovery system style cap with a SBC and a '48 Chevy radiator and it will idle all day as cool as a field pump engine.
  17. Don's Hot Rods
    Don's Hot Rods
    from florida
    60 over is not too far, I just had the 351 I am building taken out to 60 over and when I questioned the race shop that is doing the machine work he told me not to worry at all.
    Don
  18. slickhale
    slickhale
    from Phoenix
    Might wanna check the head bolts. 351 and 302 are different size bolts
  19. cylhead
    cylhead
    .060 is a standard acceptable bore size on a 302,the biggest problem is builders installing 1 head gasket on upside down which does not let the water flow quick enough to cool the engine. It is a very common problem and the temp gradually climbs to a point of overflow from radiator. Dont worry about the .060 I have bored probably 100 blocks that size with no problems. Good luck
  20. I missed the part where it says Alum. Rad. The cap is not going to be your problem. Sorry
  21. Let's get back to basics here. Does it have a coolant recovery tank (aka Puke Can, catch can)? If not then let's look at the next step. Back before cars had catch cans if you filled the radiator to the top, the first time it got fully up to temperature and then was shut off they would spit out some water. Then they would be fine. Basically they were seeking their own level. So after it puked, if you added more water, it would do it again, and so on. If you left it alone, it would be fine if everything else was working right. Usually the water would be down about an inch or so and that was fine.
    So, what have ya got?
  22. MATACONCEPTS
    MATACONCEPTS
    YES! If the oil's clean & no smoke, Let it make some expansion room & DON'T top it after.
  23. MATACONCEPTS
    MATACONCEPTS
    I love when hotroddon comes in like that. Simplicity that gets overlooked.
  24. it will dump coolant until its below the visible level, i always shut it off when i see more than several cups of water on the ground. ive blown head gaskets before and it always just overheats, this time though i can drive it for a good while and it stays under 180, but when i stop its bllowing water, and no i do not have a catch can. i did find that last week i drove it about 2 miles to a little local car show and i found that i had been leaking water leaving a trail for a while. the coolant does look like it may have a little oil sitting on top but the oil looks pretty good and not milky.
  25. I have had radiators do the same thing and it just seems thay have to seek their own level. I don't put any more water in after it blows out and they have gotton no hotter and loose no more water.
  26. i also forgot to mention that i can hear it boiling in the radiator when i shut the engine off.
  27. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Bingo...Had the same issue with my chevy stroker.
  28. MATACONCEPTS
    MATACONCEPTS
    water pump blades corrode by just using water? Is the WP good? old?
  29. Piewagn
    Piewagn
    Ding ding ding!!! Don't fill it up to the top, you need to leave room for expansion. I just fill my '66 Sub to the top of the tubes.
