Hot Rods Why does my SB overheat/ run hot?
Discussion in 'The Hokey Ass Message Board' started by BaBa, Jul 9, 2021.
  1. Rramjet1
    Rramjet1
    Since you’re in AZ you could get away with running straight distilled water most of the year. Coolant doesn’t offer as much heat dispassion as straight water.
  2. Budget36
    Budget36
    But then there’s no corrosion resistance
  3. AD trucks have a huge air space above the engine that collects hot air that doesn't get expelled. I've thought about louvering my hood to help get the hot air out.
    John Lee Williamson likes this.
  4. sdluck
    sdluck
    He moved the vacuum hose from ported to manifold vacuum and said it fixed the problem.I doubt we will here from him again.
  5. squirrel
    I run water and a corrosion inhibitor in my Chevy II, and I keep it inside it won't freeze in winter. Yes, it can get cold here.
    Lil32 likes this.
  6. gimpyshotrods
    gimpyshotrods
    There is a reason why we use Spal fans at GM for performance and prototyping.
    olscrounger likes this.
  7. Never saw any pics of the front of the radiator. Proper shrouding includes both sides of the radiator.
  8. sdluck
    sdluck
    He never answered our question.
  9. jimmy six
    jimmy six
    He is gone… This is over….:)
    Tman likes this.
  10. norms30a
    norms30a
    too bad he's gone, this is interesting.
  11. Rramjet1
    Rramjet1
    They have additives.
  12. Budget36
    Budget36
    But you didn’t mention that. Hence my reply.
    gimpyshotrods likes this.
  13. David Gersic
    David Gersic
    from DeKalb, IL
    The “Corvette” pump is “short” and moves the heater hose to the side, 9 o’clock position, vs. the straight up exit on the passenger car short pump. I’m guessing that the lower hood height on the Corvette forced this change in hose routing, but not being a Corvette expert, that’s just a guess.
    On the 68-70 pump, the shaft diameter is 3/4”. 71 and up, the shaft is 5/8” diameter, and 3/16” longer.
  14. Also check the hood where it surounds the radiator, if the shroud is not there the fan will pull the hot air back in the front of the radiator. Check rear portion of the engine compartment, the air has to get out at the rear so if there are components blocking the rear air exits the hot air won't get out. There's always, leave the hood at home, louvers or raising the rear of the hood to let more air out. JW
  15. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I see your running a Flex a lite fan.. Get rid of it... Yeah they claim big numbers but those are numbers free flow not on a radiator. Spal and Derale are the two companies who actually test theirs that way.. Those 2 companies are the best electric fans on the market...
    Ditch the flex a lite no matter what and things will improve I think no mater what...
  16. joeyesmen
    joeyesmen
    Punch some louvers in the hood - let that heat escape.
  17. A really good cooling system T/S includes measuring air flow across the core. The Semi dealers use the Blowby air flow meter and then can compare to oem requirements and power. The electric fan pictured, leaves a lot of core unshrouded. This would reduce radiator efficiency as well.
    jimmy six likes this.
