Hey guys!!! Would you share yours banger projects!!! thanks in advance!!! Need some inspiration!! I'm a little bit out of the line these days!!! I got a Hot rod Ford and two dollars bill!
I've been working on this little project off an on for a while. This photo was last fall. Here it is currently and it now runs, steers and stops under it's own power. Once all the fenders are on and a bit more work I actually plan to sell it off to get me back to work on my Roadster. The fuel tank adds a special touch don't ya think? The Wizzard
Model T truck!!! 1/4 mile banger!!! I like it!!! What's about the dizzy? It's a stock body from Ford? I got a Hot rod Ford and two dollars bill!
Yes, all factory sheet metal from 26/27 on an all Henry Model A chassis, dropped A front axle with Hyd. brakes using the stock A brake pedal. The dizzy is stock more or less Model A with manual advance on stock Model A steering column. Motor was put together by Friend and B/Ville record holder in stock body Model A so it got some special rub while in pieces. Been working at it instead of on it for way to long. Very pleased I don't have to push it any more. Looks like your parts are Model B banger parts. The Wizzard
Only the cam is model B!! Model A Block with a hole for a fuel pump, not the same place as model B block!! Model A drilled crank!!! An improvement over the oil system!! Some oil from the pump is send trought a tube gallery to the mains!! I got a Hot rod Ford and two dollars bill!
I finally started putting all the pieces together on my 28 rpu a couple weeks ago. its coming along slowly. It will be running the wide 5's all the way around. it is being powered by a '37 diamond block and a stock trans for now. I do have a v8 trans but that will come later. I will be running the splash aprons. the windshield will be chopped and laid back aswell.
Lots of cool stuff sitting around your shop bro!...your first photo looks like it's kind of cold,you pretty far north?
On top of all your guys interesting projects n stuff I really get a chuckle out of some of those funny faces you post... and Rat is that quote from a song or is it your song......Happy New Year
Fire up Youtube type in Hey Good Lookin and there it is...having a Hankfest now...He was a great Artist...Thanks Cactus 2 Bucks probably got ya lots back in those days...
I've been working on a late 30's/early 40's '29 Tudor "banger" build. Haven't gotten much done, lately! Need to get busy...
Thank you ROCKER77 . I appreciate it. I like yours also and your buddies. Yours is coming along just fine. Are you planning on painting it later? I been working on mine for about 4 years now . As I get a little money at a time. I just had a engine built for it. Its also a diamond block ,counter balanced crank ,inserts,340 Bill Stipe cam , high compression head, forged pistons. Talk to you later Rocker77. Bob......................
Mine will get paint once I get it all put together and running then I will take it all apart and paint it up. Probably gonna do Washington Blue.
Stogy!! Happy new year for you too!!! It's an old western country song!! Hank Williams Sr. https://g.co/kgs/LUl3sU I got a Hot rod Ford and two dollars bill!
Happy New Year banger guys!!! Thanks for sharing your projects!! I got a Hot rod Ford and two dollars bill!
