Folks Of Interest Who's leaf springs
Discussion in 'The Hokey Ass Message Board' started by StefanS, Jan 16, 2017.
  1. StefanS
    StefanS
    from Maryland
    So recently Maryland decided to tighten up their laws on historic tag use. Instead of never driving my car or looking over my shoulder at all times, I decided to go ahead and get it inspected and get real tags on it. I was on the fence about using my original leaf springs with blocks or getting new lowered springs to replace them. This situation kind of steered me towards my decision, since my current leaves were heated, causing an upward bend right behind the front eye. Of course, that'll cause them not to pass inspection. So my question is, should I go with Posies 3" drop springs or St. Louis Spring 3" (or 4") drop springs? I've read both good and bad on Posies over the years so I'm kind of hesitant on them. St. Louis Spring makes the leaf springs for Jamco and they're $20 cheaper than Posies even after shipping. I've only seen a few things on Jamco (St. Louis Spring) springs but they were all good. Most of the time the threads just go into how Jamco sucks, with no real review of the springs. So what's preferred...Posies or St. Louis Spring/Jamco leaf springs (as far as ride quality and longevity)?
  2. I bought Poises springs, have not run them yet, they are installed.
    Just note they take about 6-8 weeks to get.
    The seem to be 3" drop, I'm working on a '33 Plymouth
    I got Eaton springs on the rear, they also are lowered 3".
    I have yet to put the full weight on the rear wheels.
    Maybe take the car over to a local spring shop and see if you can get away with getting a couple leafs made instead.
  3. StefanS
    StefanS
    from Maryland
    Thats one benefit of going with Posies is I can drive about an hour and pick them up at their shop. The local spring shop can straighten my springs back out for $40 but I'm concerned that the strength of the springs has been compromised. They charge through the roof to make a full set of springs. They wanted $100 to bend me up some square u bolts
  4. BJR
    BJR
    Why not use stock springs to pass inspection and then change them?
  5. StefanS
    StefanS
    from Maryland
    You mean have them straighten them out just for inspection? I guess I could do that but I'd still have to figure out which springs to get. Also, if I pull the current springs out I may end up needing new bushings and u bolts. I'd rather not spend all that just to replace them anyway.
  6. jimmy six
    jimmy six
    The place where they were bent is now a weak spot. Just bending them back will be temporary.
  7. Dyno Dave
    Dyno Dave
    Stefan, I ran 3"Posie's springs in my '54 Bel Air for approxlmately 15,000 miles. Original 235 driveline, so No sidestepping the clutch and No burnouts... Yet within that low mileage the rear of the springs formed a reverse arch, dropping the car into a lowrider stance, not what I wanted. Sold the takeouts and installed a TCI spring kit. I brought and used trailer u-bolts at the local hardware store, stocked them in various lengths. Hope this info helps, Dyno Dave
  8. StefanS
    StefanS
    from Maryland
    Thats exactly what I was thinking which is why I was just thinking new springs. I also don't want to use blocks if I don't have to
  9. StefanS
    StefanS
    from Maryland
    This is one of the negatives I've read about them. Also that they ride poorly. At the same time, I've read how great they ride and how long they last. Is it luck of the draw with them or..? The few posts that I've seen actually talking about jamco product quality is all positive. Unfortunately that's only 3 or 4 posts worth
  10. Joe H
    Joe H
    This last year I replaced all four springs on my '37 truck with Detroit Eaton springs. I am real happy with them. They came with teflon (type) buttons on each leaf with new bushings. The ride is much better, and the fit was exactly right. Since I ordered custom spring rates, the price was a little high, but I new it would be going into it.
    Joe
  11. StefanS
    StefanS
    from Maryland
    I may have to look into them too. I forgot all about them
  12. StefanS
    StefanS
    from Maryland
    Just looked them up... $300 each!?! I think I'll stick with one of the two first choices lol
