Projects Who was making the FE to SBF valve cover adapters
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Oct 28, 2017.
  1. junkyardjeff
    junkyardjeff
    Pulling the 460 from my F100 this winter and replacing it with a 351-W and would like to use FE valve covers to make the motor look a little bigger since it will look small compared to the 460,might need a second set to put on the 302 in my custom 500 since that motor looks so small in a large engine compartment.
  2. junkyardjeff
    junkyardjeff
    I think it was someone on here that made them.
  3. Phillips
    Phillips
    Try dirtbag13 I think like he made them for his rpu
  4. LM14
    LM14
    from Iowa
    I sent Dirtbag13 a message over a month ago and never got a response. Was interested in them, too. Either they don't make them anymore or don't answer messages.
    SPark
    fauj likes this.
  5. junkyardjeff
    junkyardjeff
    Thanks for the info and sent a message and will see what happens,last post was in september.
  6. bolthead
    bolthead
  7. okiedokie
    okiedokie
    from Ok
    Looks like a spacer, not adaptor.
  8. Mr48chev
  9. LM14
    LM14
    from Iowa
    Get to the correct page and they do make adapters for $175
    http://medicemfg.com/product_view.php?pid=6
    SPark
    Guess Mr48chev and I were typing at the same time!
  10. Keep in mind that unless you track down an early ('62-64) SBF timing cover with the oil fill tube, you can't use the early FE round top or pent-roof covers; no place to add oil and more importantly, vent the crankcase. This cover also locks you in to the early aluminum water pump which isn't so easy to find these days. This pump also has the passenger-side-only outlet, so matching to an existing radiator may not work.
    You can use the later 'Power by Ford' covers with the oil fill/PCV holes or most aftermarket covers.
  11. junkyardjeff
    junkyardjeff
    I was going to use the 65/66 style valve covers but at 175 a pair for the adapters I might have to rethink this idea,most likely will get marine valve covers that have nothing stamped on them and put some kind of sticker on them like what I done on my sunliner.
  12. fordsbyjay
    fordsbyjay
    from Lafayette
    This is an old thread and I don't know where it ended up but I bought a set of adapters from medice years ago at a swap meet in Ohio. I put a pcv valve in my valve cover (which I regret) but I built an vent filter adapter to the fuel pump block off for adding oil using a 90* piece of 3/4" conduit and a K&N filter on top. . I just thought I would share in case anyone else was thinking of doing this.
  13. junkyardjeff
    junkyardjeff
    I have since picked up the timing chain cover from a 63 260 that has the oil fill tube and the PVC system from that 260 too and found that my 66 289 4 bbl intake just needs a hole drilled for that PCV system to work so when I get the extra money to buy those adapters I will have the parts to help make it look like they belong on the engine.
  14. junkyardjeff
    junkyardjeff
    These parts will make it much easier to use those early FE valve covers on a 302. 100_7933.JPG
  15. bluebolt
    bluebolt
    from Benton LA
    I know I am late to the party but I really like the looks of this engine and the oil fill though the timing cover is a great idea.
    deathrowdave likes this.
