Technical Who makes the best oil filter?
Discussion in 'The Hokey Ass Message Board' started by Rusty O'Toole, Oct 31, 2016.
  1. Rusty O'Toole
    Rusty O'Toole
    I know there are articles on the web, I did a search and found lots of them, but every one I saw was 8 years old or older. Does anyone know of any tests done more recently?
  2. 73RR
    73RR
    I found a web page, obviously funded by Amazon, listing the 'top-30'.....the list included 5 different Fram filters and not one Wix filter....hhmmmm...me thinks there is a flaw....
  3. sunbeam
    sunbeam
    From an oil analyois company the company I worked for used Fleet Guard.
  4. evintho
    evintho
    There was a very comprehensive one done a few years back that was extremely detailed. It dissected every leading filter on the market, preformed tests, etc. Based on that info it seems Purolator is definitely the best bang for the buck and it's the only filter I use on all my cars. Fram looks to be junk! But hey........opinions vary!
    6-bangertim, slack and GreenMonster48 like this.
  5. Rusty O'Toole
    Rusty O'Toole
    Yeah I looked at some of those 'top 10' and 'top 30' lists all obviously shills. There were a few comprehensive, detailed analyses but the newest one I found was from 2008. Wonder if there is something more up to date.
  6. uncleandy 65
    uncleandy 65
    Back in the day we used Scott toilet paper in the canister filters.
  7. Rusty O'Toole
    Rusty O'Toole
    I've got one of those Frantz filters but never used it. New cars don't seem to have any room under the hood to put one.
  8. 49ratfink
    49ratfink
    the machinist who built a few motors for me said to use Wix. he actually scolded me when he saw a Fram on a 289 he built for a Mustang I had.
  9. IndigoInkTaco
    IndigoInkTaco
    from Jersey
    After doing some research, it was somewhat unanimous to go w/ Napa/WIX, so I just put a Napa Gold filter on mine.
    Although I have to say, after trying to obtain the correct filter by emailing wix, they have pretty poor customer service. The guy seemed more worried about their liability in recommending the wrong filter than helping me ensure I'm using the right one. After a lot more cross checking and researching than needed, I found the correct one anyway, but no thanks to Wix's CS rep.
    lothiandon1940 and Gman0046 like this.
  10. Yep, Wix/NAPA filters are the good ones and easy to find, Motorcraft is another but not so easy to find, Fram is junk.... There's some other good ones (Purolater, AC, Bosch), but they're harder to find and don't have coverage for everything. Wix makes filters for damn near everything.
    Harley used to sell a 'Screaming Eagle' air cleaner assembly as a hop-up part for their bikes that featured a K&N washable filter element (made to order for Harley). HD switched to Fram as their supplier, the now-paper filters immediately got a bad rep as the filters would disintegrate and get ingested into the motor....
  11. Rice n Beans Garage
    Rice n Beans Garage
    Frame installation instructions:
    1. Confirm application
    2. Open box
    3. Remove from box
    4. Toss in trash can
    5. Pat yourself on the back
    DO NOT REPEAT
    slack, robracer1 and gimpyshotrods like this.
  12. Gman0046
    Gman0046
    IndigolnkTaco X2.
  13. AKGrouch
    AKGrouch
    I'll just stick with Wix
    nunattax likes this.
  14. 19Eddy30
    19Eddy30
    from VA
    Wix--R filters
    falcongeorge likes this.
  15. gimpyshotrods
    gimpyshotrods
    SBC's and citrus fruit are the only things that are good and orange.
    I would not install a Fram filter on cinder bock, let alone anything that needs to have anything filtered.
  16. Funny!
    I bought a box full of Fram filters at a swap meet for 10 bucks and found the ideal use for them ~ Target Practice! HRP
    lothiandon1940 and Hotrodmyk like this.
  17. LOL I can't tell you who makes the best filter, I can tell you that I don't. Hell from what I have been told I don't even choose a good filter.
    Wix makes a good filter, or at least they did at onetime. Back before anyone really knew what a Wix filter was we called them a farmer filter because farmers used them a lot. if you think about it, its really not an insult, who gets the best value out of everything that they buy and use? Farmers do.
    clem, Cosmo49 and Truck64 like this.
  18. The local cab company use to be next to our business and they used Wix,I figured as much punishment as cabs get they know the best filters. HRP
    lothiandon1940 likes this.
  19. I bought some Wix XP filters for my 355, they're 21 microns. I started the break in with a Royal Purple which is also good. I always go with a longer filter than the stock one. Moroso makes one that I liked as well and is carried by my local speed shop.
  20. Hnstray
    Hnstray
    from Quincy, IL
    I am a WIX fan..........
    Ray
    nunattax and falcongeorge like this.
  21. RmK57
    RmK57
    Motorcraft FL-1A in my older Fords. Heard there made by Purolator which also have a good filter.
  22. IndigoInkTaco
    IndigoInkTaco
    from Jersey
    Keep in mind, I believe Mann also acquired wix earlier this year. I have no idea if that will change anything in the design/quality of their filters, but maybe something to keep an eye in the future. I'm sure the folks over on BITOG will be monitoring this for masses as well :)
  23. H380
    H380
    from Louisiana
    I use Wix or the long truck AC Delco on my SBC. Depends on my mood. Honestly nothing wrong with AC Delco or Motorcraft. Try them out and then cut open an old filter to look at the construction.
  24. BigDogSS
    BigDogSS
    from SoCal
    My engine builder, who's been around the block 10,000+ times, said to use WIX in my newly rebuilt, not cheap 327. I order them a couple at a time through RockAuto.
    Here a tip --> When you buy a filter at a store, open the box to make sure the correct filter is IN the box. I've came across this issue a couple of times. It just saves the aggravation of returning the filter for the correct one.
    6-bangertim and bobss396 like this.
  25. gimpyshotrods
    gimpyshotrods
    Mann is an OEM for European cars.
    If it can filter a six-figure hypercar, it can filter your hot rod.
  26. slowmotion
    slowmotion
    I bailed off the Fram bandwagon sometime around the mid 70's. Seen three different failures first hand. Napa Gold/Wix these days. And they're easy enough to find.
  27. Atwater Mike
    Atwater Mike
    Our resident counter man at O'Reilly's cut open some new filters, at the O.K. from his boss.
    Fram has a 'shorter' paper element (and less dense) besides a spring plate (just a circle of .020" steel compound curved for tension) that does NOT keep tension on the filter gasket, lots of oil bypasses it.
    WIX and Bosch have denser filter paper, and a coil spring at the tension end.
    Cut open a WIX, then a Fram. Obvious.
    6-bangertim and mctim64 like this.
  28. Rusty O'Toole
    Rusty O'Toole
    The local parts store sells Fram, Mann and K&N.
  29. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    It is my understanding that wix manufactures filters for a number of other companies besides napa. Also the last time I looked at a puralator box it said made in Vietnam! That's been some time ago, and most of the products we buy are made by someone who probley dose not even know what it is used for. Use good oil and change it with the filter every 3,000 miles or once a year and you won't have any issue's . And if your motor blows a filter apart, you got more problem's than filter quality. Larry
  30. dan31
    dan31
    On my big trucks and equipment we would only use wix. I'll run k&n on my car motors
