Hot Rods Who makes 7" headlights with signal lights?
Discussion in 'The Hokey Ass Message Board' started by Groovy, Oct 11, 2018.
  1. Groovy
    Groovy
    I know So Cal sells them but I think the marker light on top of them look silly because of the high peak they have. Is there another mfg that makes something similar with a softer looking marker light on top?
    ... Also what options are there for small 50's period style stand alone signal lights?
  2. choffman41
    choffman41
    Is a hadlight one that doesn't light up anymore?
    Texas Webb likes this.
  3. Groovy
    Groovy
  4. KoolKat-57
    KoolKat-57
    from Dublin, OH
    There are some European 7" halogen headlights that have a second smaller bulb socket built into the reflector.
    I believe Hella or Cibie has them.
    KK
  5. Blake 27
    Blake 27
  6. banjeaux bob
    banjeaux bob
    from alaska
  7. 34Phil
    34Phil
    For the electrical gurus, is it possible to rig relays without adding a digital timer to have one headlight turn off while that blinker is on like modern cars?
  8. Shadow Creek
    Shadow Creek
    from Summit, TX
    I’ve often wondered about this also, it would definitely make the signal more visible if it’s possible to do. Curious to see what turns up.
  9. Why not use the high beam as your turn signal. It worked great on my C cab. Of course you will have no turn signals while in high beam mode.
  10. ramblin dan
    ramblin dan
    I don't know if this would help but this diagram appeared in street rod mag. I believe back in the 80s how to turn your headlights into turn signals. It looked interesting and am img276.jpg thinking about this set up.
    my34tuda likes this.
  11. 51RuiLaquzL._SX425_.jpg I think Peterbilt used a headlight bucket that had a signal lens built into the top edge of the ring.
  12. Groovy
    Groovy
  13. JeffB2
    JeffB2
    from Phoenix,AZ
  14. GearheadsQCE
    GearheadsQCE
  15. pprather
    pprather
    I have a pair of repro '33-'34 commercial lights with Bob Drake reflector, halogen bulbs and internal park light/turn signal. PM if interested.
    Phil
  16. Elcohaulic
    Elcohaulic
    I hope you don't depend on other drivers actually seeing them, especially with the nit wits on the road today!
    F&J likes this.
  17. dodgedifferent2
    dodgedifferent2
    I was just doing some random googling on this.
    Never seen anything I cared for or bright enough.
    Those peterbilt ones I may do some more digging on those but i cant see them outshining a headlight
    F&J likes this.
  18. banjeaux bob
    banjeaux bob
    from alaska
    There are other vendors who might have them on the shelf.PPRather a few posts up says he has some for sale as well.
  19. Groovy
    Groovy
    After searching Bob Drake's products I found the look of the repro 682-c headlights to my liking...
  20. pprather
    pprather
  21. Blue One
    Blue One
    from Alberta
    I have the OTB 682C.
    I really like them.
    Park lights and signal lights on the top.
    OTB makes really nice stuff and they are good to deal with.
    I also ordered the headlight wiring conduits from them.
    http://www.otbgear.com/682-C-Headlights-C3.aspx
    5B9EB93A-B3B1-4516-8BBD-A7BDC7D66CA3.jpeg B86AD84C-64A9-476F-81E9-9FC92FA736A7.jpeg
    catdad49 and ramblin dan like this.
  22. Groovy
    Groovy
    Thanks for the photos Larry. I see that the OTB's are horn shaped which I don't like much. The Bob Drake 's have a rounder lens which I like more. Did you get yours from SoCal?
    --- Bob Drake on the left ---
    --- OTB on the right ---
  23. Blue One
    Blue One
    from Alberta
    No problem, I hadn't seen the Bob Drake ones.
    We actually got mine right from OTB, my wife ordered them for me for Christmas one year.
    They’re good quality and I’m sure the ones from Drake are as well.
  24. dmdeaton
    dmdeaton
    I just mounted up a set of the 682-c repops that Speedway sells. I think they are junk. The screws for the bezels are almost stripped from out of the box and I had to redo the turn signal sockets as the brass spring pins were bent and not making contact. The 4 screws that hold the mounting plate on the bottom of the lights is crap. It is meant to look like a rivet and has no slot or flat. They don't tighten up, as the head just spins with no way to hold it while tightening. Sorry for the rant, and I know I shouldn't have ordered from them. I will use them until I find a good set of originals.
  25. dmdeaton
    dmdeaton
    I also put a LED conversion in mine which I really like. Hardly draws any current.
