Who has a STRAIGHT 6 in your HotRod? Come On, stand up!
Discussion in 'The Hokey Ass Message Board' started by AHotRod, May 25, 2004.
  1. Inline6Guy
    Inline6Guy
    My 57 F100 is runnin a 300c.i. Ford 6 with an AOD and 370 gear. It has an 4bbl Offy dual-port intake and EFI cast iron headers and full duals. Weighing in at 3650 lbs, it runs OK but it's no hot rod. I built it to be a tow vechicle with a reciever hitch etc., and it will do that nicely. About 14 MPG (no load).
    http://picasaweb.google.com/Inline6guy/MyDriver#5543987569157334978
  2. cjmac
    cjmac
    Got one here. Not pretty, but different.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Wow Cjmac, that's a really bitchin' air cleaner assembly on your truck. I can see dual carbs with two of those side-by-each.
  4. DougHH
    DougHH
    I'm pulling the 235 blue flame out of my '59 belair and jamming a 283 w/350 combo in it soon. I'll take that 235 and will either jam it in my '36 chev mordoor or my '26 chrysler rpu. probably the 36 chev to be honest. Gunna get it converted from the p-glide to a borg-warner manual
  5. 40FordDeluxe
    40FordDeluxe
    I have a straight six in mine, but it may not be Hamb friendly.........................
  6. DirtyEd
    DirtyEd
    from Dallas Ga.
    Here is a photo shop of the finished car I hope to be rollin in this spring.It will have a 200/C4 for a later mustang.2.90 geared 8 inch ford rear,so it should roll down the highway no problems.
  7. mspurgeon
    mspurgeon
    For my T Project I got a 223 with a 3 speed. All stock at this time. Not even started on the engine, Just setting on a cart waiting for me to finish the frame.
  8. GTA91
    GTA91
    from Festus, MO
    Pontiac OHC Sprint 6 right here. :)
  9. AHotRod
    AHotRod
    Any of you guys get good gas mileage with your 6 ?
  10. wolfex1
    wolfex1
    Absolutely! Running a 292 with twin Weber progressive two barrels, four speed, and a 290 rear gets me 20/22 MPG if I behave myself. I get a kick when my buddies with the BBC's stop for fuel when I am still running 3/4 of a tank. Sure, they can blow me away at the light, but who races on the street anymore anyhow? I draw more attention at shows with my six because who hasn't seen a billion chromed/billited V8's? You can't swing a dead cat by the tail at a car show without hitting a SBC.
  11. GTA91
    GTA91
    from Festus, MO
    My sprint 6 is in a '52 pickup with a T5 (.72 OD), 3.90's, and 28" tall tires. It got about 18mpg average on our Frog Follies trip last August. That was mixed driving. The motor is bored out, has duals with glasspacks, and a pertronix ignition... otherwise the setup is stock as is its quadrajet.
  12. @ Westerman: Like that clean engine bay can you post some close ups.
  13. ford5t1
    ford5t1
    from usa
    got a 300cui in mine '65 ford f100 mild custom. Runs like hell. Have the three on the tree and have to get other gears in the back.
    See ya
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    300 Ford: 17 mpg
    300 Ford: 2/3 gal per run
  15. Big T
    Big T
    from Florida
    Straight six, yes...
    Hot Rod? Not even close. :)
    Stock 1953 235
  16. custom300
    custom300
    I ran a 225ci slant six with a offy valve cover and weber 2bl. in my Model A. It was from a 70 duster.​
  17. 50ChevyFrank
    50ChevyFrank
    40FordDeluxe, that's a Cummins, right? Sweet!
    Not a hotrod but here's my original 216 in my 50 pickup.
    MO54Frank likes this.
  18. Bigcheese327
    Bigcheese327
    What's that intake setup?
    -Dave
  19. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    The intake is a Clifford 2 x 4 with homemade two barrel adapters with two Autolite 1.08 2Vs. It works great with no heat (other than the cramped underhood confines of the '33 Willys coupe). No stumbles, bog or weak tip-ins.
    Runs 13s at the drags on street rubber.
  20. 40FordDeluxe
    40FordDeluxe
    Yes it is, in a 68 Corvette.
  21. coultas
    coultas
    from Washington
    tell me more about.your 302 GMC. Source of rebuilt parts, bolt on, any information to help with my 302 project. Coultas
  22. clutch58
    clutch58
    223 in my 59 f100, 200 in one of my 66 mustangs, both stock for now
  23. BISHOP
    BISHOP
    Mine.... Ford 300, in a 33 Ford pickup. Still in mock-up stage. It does run good now..
    I will post more pics as I get things done. Motor will be gold in color.
      235.2 KB
      263.2 KB
      80.8 KB
      251.5 KB
      324.6 KB
  24. edgeabilly
    edgeabilly
    What a great thread!!!:D
  25. adamshumard
    adamshumard
    Got a 235 in my 54 kustom I'm building. split stock exhaust manifold. wouldnt have it any other way. too many sbc's in em i think.
  26. gobi
    gobi
    This was my first Aircleaner:
    Because of heat problems, I build this instead:
    Gets the air now from outside
  27. EchoOfGecko
    EchoOfGecko
    Here's mine. Not all that pretty, but it runs like a champ. Will probably get replaced by a SBF in a few months. :)
  28. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    This isn't really an air cleaner per se, but I did fab up this formula-like scoop for my RPU six-banger, from .060 aluminum.
  29. RobsHemiA
    RobsHemiA
    Sorry about the OT glass body , but this is my model A pickup with 292 . New long motor on the way with big cam to go with the dual weber's and 2 peice headers . Should be a fun car !
  30. wolfex1
    wolfex1
    Looks like the same Clifford set up as mine. I had problems with blowing/burning out the paper gasket for the intake/exhaust to head, due to, I believe, to the uneven thicknesses of the mounting flanges and Clifford not providing any hold down pieces that go in between. PM me if you run into the same problem. I think I have the problem finally solved. ~WX1
