Technical White steering wheel
Discussion in 'The Hokey Ass Message Board' started by 57 Fargo, Apr 9, 2020.
  1. Totally being lazy as I sit outside drinking coffee watching the toddler and dog play. IMG_1727.JPG
    Anyone know of a white metal flake steering wheel that’s available, new or used.
    I have done zero research for myself, hoping someone will take pity and help a brother out!
  2. Black_Sheep
    Black_Sheep
    I spent a lot of time looking for a white steering wheel for my 58, I don’t recall ever seeing a white metal flake steering wheel. There is a Facebook group for metal flake steering wheels, If you use Facebook that might be a place to start.
  3. V8 Bob
    V8 Bob
  4. Seem's Grant made/make's one. HRP
  5. I know Moon still makes a white steering wheel and a silver metalflake one, but I don’t think I have ever seen a white metalflake wheel.
  6. Well maybe I’m looking for something that doesn’t exist then, maybe it’ll be plain white.
    Thanks for the suggestions, what did you end up going with @BLACK SHEEP?
  7. rudestude
    rudestude
  8. BoogittyShoe
    BoogittyShoe
    Would it work to spray a white wheel with clearcoat/metalflakes? (Then multiple clearcoats)?
  9. I missed the past about white metalflake, I've never seen one. HRP
    dana barlow likes this.
  10. ididntdoit1960
    ididntdoit1960
    from Western MA
    Wouldn't white metalflake be......silver?
  11. kidcampbell71 likes this.
  12. Lou kriger
    Lou kriger
    Yep.. what he said
  13. Ok, the white metal flake would be metal flake over a white base, silver metal flake would be metal flake over a silver base.
    If I am doing the entire interior in white then would the silver flake wheel stand out? Or should I go with plain white? Looking for opinions.
  14. What kind of wheel are you wanting? As mentioned you could paint a solid wheel white and then paint white flake over that and clear. If you are looking for the usual metal flake style wheel then I would think solid white would look better that silver.
    Sent from my SM-G950W using The H.A.M.B. mobile app
  15. [​IMG]
    Grant silver metal-flake steering wheel, JEGS
    HRP
  16. V8 Bob
    V8 Bob
    I'm using a plain white wheel with an all white interior in my '40.
  17. Looking for a wheel like this. Only in white, although maybe I should paint an original. Hmmm.....
    I also have one out of a 59 regal.
  18. I assume those are solid wheels that are just painted with metal flake if so you could get a solid white one and flake it yourself with white flake. Edit: I see Mooneyes says they are rubber so I would be leery about painting one. I painted this one white (was Black) for my truck would be easy to add flake to it as well.
  19. yea grants are as well so I’m leery of painting them as well, I’ll likely just go with white and call it good.
  20. Jalopy Joker
    Jalopy Joker
    looks like white metal flake available in vinyl - wrap a wheel like is done with leather? 20200409_141310.jpg 20200409_141238.jpg
  21. Black_Sheep
    Black_Sheep
    Moon Eyes has several styles and diameters of white wheels, I chose a Grant due to the shallower dish. Con2R has a lot of options too but they are kind of expen$ive
    57 Fargo and 1935streetrod like this.
  22. Oops! I wrote this up hours ago but went to run some errands and never posted.
    Metal flake steering wheels are usually transparent, "candy" colors. So a"white" metal flake wheel is usually clear with suspended silver flakes embedded throughout and is often designated as "silver" when you are doing a search.
    A solid color, opaque white with some flake blended in is going to be sort of rare, I would think, but anything is possible.
  23. oliver westlund
    oliver westlund
  24. This makes sense, I’m actually really digging the grant in @Black_Sheep truck. I’m assuming 15”?
  25. BoogittyShoe
    BoogittyShoe
    I meant to spray a white wheel with clearcoat with gold or silver flake in it. It would probably wear pretty quickly though.
    Black_Sheep likes this.
  26. Black_Sheep
    Black_Sheep
    Yes. 15" wheel.
  27. Awesome thanks guys
  28. To do flake properly you spray it on over the base (usually in an intercoat clear) then bury it in a bunch of clear coat. Would wear just as well as any other part painted in automotive paint.
    57 Fargo likes this.
