where's the VIN at on a 34 dodge?
Discussion in 'The Hokey Ass Message Board' started by rebstew187, Aug 2, 2007.
  1. rebstew187
    rebstew187
    can anyone tell me where the VIN is on a 34 dodge 4 door? on the front door post? frame?
  2. Devils_Instigator
    Devils_Instigator
    from Tejas
    Hey Reb its Woody from the Devils Den. Look down on the floorboard on the drivers side. I know that old Dodges hadem there.
  3. Lets' see what my book says, usually they're on the right side door post at the cowl on this era Mopar.
    Well, for 1934 it says "same location" .. so for 1933 it says front right door hinge pillar post. Which is what I thought. The ones I have seen are riveted on, an aluminum tag with black background and silver bar for the numbers, about 3" long and 3/4" or so tall (technically it's 3" tall since they mount sideways). So if you have a couple small holes about 3" apart, it's gone.
    So if you need the number info for the 1934 serial number range let me know.
  4. rebstew187
    rebstew187
    thanks for the info guys. looks like someone may have it hanging on their garage wall or something. I'll figure something out.
    welcome back woody
  5. Chaz
    Chaz
    Riders side door opening on mine...
  6. Slicks
    Slicks
    from denison tx
    I Had A39 Chrysler It Was On The Frame Left Rear Wheel
    Slicks
  7. signalsteve
    signalsteve
    from NH
    passenger side door post on my 34
  8. I think the passenger door post is probably accurate.
    On my 47 Plymouth, the same number that appeared on the
    original engine is stamped into the frame, on the outer side,
    in an area beside the left rear wheel. Probably need to do some
    wire brushing to uncover it.
    Don't know if they did it the same way in 34, but on a 47 Mopar
    the engine number appeared on the title, plus the frame,
    and the tag on the door post is a totally different set of numbers.
  9. on my 35 plymouth I believe it was on the passenger door post
