where to get large nut for wheel puller?
Discussion in 'The Hokey Ass Message Board' started by oldpl8s, Mar 29, 2013.
  1. oldpl8s
    oldpl8s
    I'm trying to make a copy of this home made wheel puller for my American Austin. I need to find a nut with 2-3/16 inside diameter and 16 thread per inch. Any ideas on where to find one? thanks
  2. ChassisResearchKid
    ChassisResearchKid
    from Michigan
  3. simplyconnected
    simplyconnected
    How is that supposed to get the wheel off?
  4. Try McMaster-Carr or your local Nut and Bolt shop.
  5. Pete Van Hoon
    Pete Van Hoon
    Does it have to be a nut.
  6. maniac
    maniac
  7. oldpl8s
    oldpl8s
    The car has disk wheels. The tool screws on in place of the hubcap and the center bolt pushes on the axel to loosen the wheel.
  8. oldpl8s
    oldpl8s
    I called them. Apparently this is an odd size and they don't have it.
  9. Engine man
    Engine man
    from Wisconsin
    Almost any machine shop can make one on a lathe.
  10. Nuts are specified by the major diameter of the thread.
    Not inside diameter.
    Any knowledgeable machinist, can make one on a lathe.
  11. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yes ,measure the thread Od on the hub and try again. Or make one on a lathe.You DO have a lathe don't you? LOL
  12. Engine man
    Engine man
    from Wisconsin
    Check page 4. There is a 2 1/4 - 16 that is probably the size you need. Find a local truck or trailer repair and they might have it.
  13. Those thin nuts will make a lousy puller. They'll bend and deform and, maybe, ruin the wheel. I wish I were a better machinist. I have a lathe with thread cutting capabilities, but have never taught myself to use it. And I'm close to you, to boot.
  14. Carter
    Carter
    Most of the trailer spindle nuts are also available as a thick locking single nut now, instead of the two thin nuts.
    Those would be strong enough to base a puller on.
    Sent from my DROID device using the TJJ mobile app
  15. Cerberus
    Cerberus
    I have owned and maintained Harleys from three different decades. I recall Harley does use 2 1/4" nuts on their transmissions/clutches. They even have pullers for 2 1/4" nuts. Check this part number 910-968 at www.JPCYCLES.COM. to get to the Specialty Tool section.
    JP Cycles sells JIM'S Specialty tools. He sells pullers for 2 1/4" nuts.
    May be worth a shot. Don't know about the threads. Also may be right-hand thread or left-hand thread. The newer 6-speed transmission use a 2 1/4" nut.
