Im looking for some 4" lowering bocks for the rear of my 49 Chevy coupe. In a previous post some said chevs of the 40's had them but i only found 3" on their webpage. Where can i get 4" lowering blocks at? Matt
you will find that 4" is too much unless you C-notch the rear frame also drive line tunnel interfearence issues.. 3 or maybe 3.5" is about all you can get with out your axle slaming into your fame..or having scub line issues
I wouldn't do 4'' blocks, you will be way below scrub line. On my 51 I am running 3'' blocks and I pulled two leafs out of each side and it dropped it about 5'' with no scrub line issue. If you only want to go 4'' then just pull one leaf out of the back. http://www.jalopyjournal.com/forum/album.php?albumid=2404&pictureid=51269
I had 4" blocks made at a machine shop. They work for me. I have air shocks which help a lot and my springs aren't stock either.
