Its on the front left frame horn. Might be right but pretty sure it is left. Stamped in the steel will be model number ie.. C-20 then the vin number under it ie.... 1140. If you don't have frame or engine then you can check the fender apron near the left door there should be a data plate riveted on. If you don't have fender and apron then your out of luck.
