Where have you mounted your Tach? Kustoms and Hot Rods
Discussion in 'The Hokey Ass Message Board' started by zep058, Feb 20, 2013.
  1. zep058
    zep058
    I had a look to see if there is a similar thread...
    So how about showing us where you have mounted this handy piece of equipment in your Kustom or Hot Rod...is it concealed or on show?
    I picked up a Tach and am working out where I should mount it, either on the column or low, like below the dash.
    Here' some ideas I found in other threads, wheres yours?
  2. mattrod68
    mattrod68
    my buddies car, TotalPerformance on the H.A.M.B.
    my truck
    one more because i love my tach
    matt
  3. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
  4. Pontiac Slim
    Pontiac Slim
    For me it depends what its 2-b used for...I've had mine about everyplace and I like it here
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
  6. Groovybaby6
    Groovybaby6
    from Denver
    In the dash...
  7. In most cases, when it's mounted on the column, you can't see it over the steering wheel -- unless you're sitting up like a Prairie Dog. In my rpu I tried mocking it up on the column, then mounted it under the dash.
  8. chubbie
    chubbie
    i laughed when i saw this picture! a 216 with a red line at 5grand then i thought........it's a hotrod:confused: and it looks great!
  9. saltflats
    saltflats
    from Missouri
    On my 65 chevelle I gutted the clock and installed the tach in it and kept the clock face so when the needle is at 12 oclock it is 0 and 1 oclock is 1000 and so on I will try and get some pics it snowing its ass off now.
  10. Iron Dog
    Iron Dog
    from Minnesota
    My 51 Ford.
  11. HotRodToomer
    HotRodToomer
    I couldn't really find a better place, its too big of a tach.
    The new R.A.C. will look a lot better, especially with the matching, "Motor Monitor", gauge next to it.
  12. Jims35
    Jims35
    35 chev standard with a 34 master dash.
  13. 64falconsix
    64falconsix
    from Daphne Al.
    This is my current tach , I will keep the same mounting location but will be going with a 3 3/4" tach without a shift light in the near future.
  14. Mine usually end up mounted just like this. I have stuck then in the dash and one the dash but mine usuallt end up mounted just like this.
    Oh after this pic opens if you double click it you will get a new window and you can zoom this bitch so large that you have to scroll around to see everything.
  15. chubbie
    chubbie
    hotrod? you have 2 choices. on the dash, or on the column. you can't beat a sun super on the column with a hose clamp for looks!! if your bang'n gears a knee knocker just doesn't work:eek: a custom if it has a tach i would put it in the dash
  16. 35WINDOW
    35WINDOW
    Here is mine-
    • Tach.pdf
      263.9 KB
  17. no55mad
    no55mad
    Used the dash radio hole.
  18. Here is mine!
  19. tfeverfred
    tfeverfred
    I mounted mine on the column in my T. I have to lean over to read it, while driving. But since my cars an automatic, I usually only use it when tuning up my engine.
    Growing up, hose clamped to the steering column was just the thing to do.
  20. TudorJeff
    TudorJeff
    Pontiac left a nice spot for a 3-3/8" tach as long as you don't need to know what time it is. It slid in there nicely with just a little boring out of the clock cup and most people passing by don't even notice it is not the stock clock.
  21. Post Apocalyptic Kustoms
    from Outside
    Dow there out of the way so I don't get mistaken for a Hot Rodder. :D Ever tried to find a 4 grand tach? Not easy to come by but VDO makes 'em still.
  22. super-six
    super-six
    I'm satisfied with the position of my tach but I need to make some kind of mount to get rid of the strap around the steering column.
  23. thunderplex
    thunderplex
    In my 1956 Ford Mainline...
    Sent from my DROID device using the TJJ mobile app
  24. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Heres the motor in my '50. Not a 216 but a 401 Nailhead. Now who's laughing! :D
  25. Jay.S
    Jay.S
  26. chubbie
    chubbie
    F'n A!!!!! thats set up right!! right down to the fire extinquisher overflow!!
  27. NickJT
    NickJT
    from S.E. PA
    Made a bracket to secure it to the steering column support
  28. saltflats
    saltflats
    from Missouri
    Finally fucking snow anywah heres the chevelle with the clock tack.
  29. thunderplex
    thunderplex
    Ahhh, ...a tic-toc-tach!!!
    Those were cool!!
