Do you have a independent muffler shop in your area? these guys can usually help you with specialty exhaust pipes. HRP
It's a thought. I can't be much help but why not send Tommy a PM and pick his brain,,he has been in the business for a long time,he might be able to point you in the right direction. HRP
Hey, Dave. Tony's muffler on Broad Rock is run by an old gearhead, don't know if he can get you stainless or not. I bought some stainless exhaust tubing to use as my steering column tube on "that auction site" at a really good price, if you check out listings you can generally find contact info and they will be able to supply you with tubing and bends. Good Luck!
Dave, did you look at "cone engineering" ? http://www.coneeng.com/mufflers.html I didnt see a "kit" but they have everything to stack up your own kit and they are an alliance vendor.
I've done this trick so many times already- build it out of PVC pipe. Count your bends and place your order. The first time I did this I returned the PVC fittings. The second time I returned them again. The third time I just kept them. I grabbed universal builders kit ( in 2.25 aluminized though) and had plenty left over, there was more than I needed. Eventually I used it up. You could count the bends in a kit like that and duplicate the list out if 2" stainless but its not cheap having extra stainless.
SST has "builders parts" with mixtures of various bends, plus they have U-bends and straight tubing. Also SPD in Sacto area has bends and strait tubing.
Here's a source I use. They'll have it. http://stainlessworks.net/index.php/ Link to kits: http://stainlessworks.net/index.php...build-kits/exhaust-builder-kit-butt-weld.html
