when boxing A frame what did you do for body mount nuts?
Discussion in 'The Hokey Ass Message Board' started by bigvinny, Sep 30, 2012.
  1. bigvinny
    bigvinny
    any suggestions captured nut size-types or did you do some thing different- acess holes?
  2. RichFox
    RichFox
    I guess you could weld nuts in the frame before you put on the boxing plates?
  3. rustang
    rustang
    I made access holes in the boxing plate... enough to get my fingers in and start the bolts and get a wrench in to tighten...
    Tom
  4. bigvinny
    bigvinny
    I thought about that but wondering if bolts would need much wiggle room like a captive nut.
  5. bigvinny
    bigvinny
    the access holes with a hole saw would be good
  6. BurnoutNova
    BurnoutNova
    from USA
  7. bobscogin
    bobscogin
    +1. Used a hole saw and put the hole at the top edge of the inboard side.
    Bob
  8. merc49
    merc49
    from illinois
    i welded a 1/2 in. plate and then drilled and tapped the plate.
  9. I have drilled access holes and drilled and tapped the frame in areas that didn't allow holes. HRP
  10. Harms Way
    Harms Way
    Use a step drill to chamfer the hole,... use a flange nut and drop it in the hole upside down..... weld it up......
    These guys....
    Or weld nuts into place before you weld in the boxing plates.....
  11. CRH
    CRH
    from Utah
    This thread gives me hope... I thought I might be the only one who excitedly boxed my Model A frame, and then realized I hadn't given much forethought to mounting holes and accessing them!
  12. Gloop
    Gloop
    from NJ
    That's exactly what I did.
  13. bigvinny
    bigvinny
    great tips, thanks
  14. Roadsterpu
    Roadsterpu
  15. I just made 6 simple brackets on the inner frame rails. I also used swag bar bushings as body bushings. Kind of hard to see in the pic but it is all I have.
  16. VonKool13
    VonKool13
    X3.
    Worked great for my RPU. I then poked holes in rubber strips for padding under the body.
