Wheel fitting
Discussion in 'The Hokey Ass Message Board' started by gavin, Feb 25, 2009.
  1. gavin
    gavin
    from Sonoma
    I've put a 76' Maverick rear in my 53' ford, now the center wheel hole/flange doesn't fit over the end of the axle. I want to keep the stock wheels so I need a solution. Should I machine the hole on the wheel bigger? Machine the axles down to accommodate the hole on the wheel? Use spacers? Find different wheels? I'm sure plenty of people here have run into this. Any suggestions?
  2. dave lewis
    dave lewis
    from Nampa ID
    Gavin , I would have the axles machined..
    Dave
  3. choppintops
    choppintops
    With a big enough lathe, its only a 5 minute job and easy to do. Even check your local high schools auto shop, they might do it.
  4. X3 machine the axles
    unless you need a spacer for width adjustment anyway
  5. TomP64
    TomP64
    from Vancouver
    Machine the axles down leaving a 1/8th inch ridge of the original diameter to locate the drum.
