My 1952 Chevy needs a new wheel bearing in the left front, the going rate at my local NAPA is $110. I was wondering if anybody knows if there is another vehicle's bearing that will work on my car that is not as expensive?
Kanter auto parts out of New Jersey sells kit for both sides inner and outer with seals for $159 they are ball bearings probably from the J A Pan co or neighboring country
get in touch with this co : Wu Kevin <[email protected]> Dear Wu Kevin: Please send me the following bearings & seals. 4 each 909067R=1.746 USD 4 each 909052R=2.539 USD 4 each seals We can send it for you with DHL. . And pls tell me your detail address, name, tel.
You can avoid the huge mark up in bearings by skipping the middleman and getting them from a company that sells just bearings, like this one: http://www.nationalbearing.com/ If you can supply them a part number they can probably help. Where do you think NAPA gets bearings?
Didn't you just post this the other day and Squirrel posted a link to Rock Auto where they're like $30 or so?
In most cases it's possible to convert to tapered rollers. Aside from the bearings, all that's needed is a spacer/seal surface piece and an appropriate seal.
