Technical What's your favorite spray paint?
Discussion in 'The Hokey Ass Message Board' started by rockable, Sep 17, 2021.
  1. rockable
    rockable
    I have grown really fond of Dupli Color's engine enamel. Once you learn to not spray it on heavy for the first 2 coats, it works well, looks good and dries FAST. I really like that last fact, as I always seem to get impatient in waiting for other spray paints to dry.
    The cast aluminum (DE1615) and the satin black (DE1635) have worked really well for me.
    What spray can paints do you recommend?
  2. TagMan
    TagMan
    I've used Rustoleum spray paints for over 40-years and have had excellent results.
  3. A 2 B
    A 2 B
    Ditto on the Rustoleum. I like it the best. I also use the cheaper tractor paints from Princess Auto or Tremclad, "stroking on the sunshine...right over the rust". If it's something I am being real particular with I mix my own.
    I do have a few cans of the Dupli Color engine enamel but haven't used it yet.
  4. Mr48chev
    I used to use the Napa house brand Martin Senior (sp?) when I had easy access to a Napa store. Haven't bought enough spray paint in the past few years to write home about. I did use Duplicolor primer and spray paint to paint a fender on my ot daily and I was really happy with it.
    Deuces likes this.
  5. ahshoe
    ahshoe
    Krylon... It takes forever for Rustoleum to dry.
  6. Bob Lowry
    Bob Lowry
    Ditto Ahshoe above...dries in about 10 minutes to touch most times. Always wondered why someone
    hasn't come up with a paint that dries hard in 3 minutes or less for us hot rodders that are working
    on getting something put together quickly at times. If 10 minutes is good, how many less minutes
    are better...?
  7. Splitbudaba
    Splitbudaba
    457DD7E0-62A8-43DF-9AE5-7E810D1D983C.jpeg Krylon is on my coupe frame and everything else! Lays down great flows out and dries fast! Not to fussy! I plan to paint the body with the gallon of primer red made by Krylon!!
  8. I'd like to know what the taggers/graffiti artists use. That shit is everywhere, doesn't run, and lasts forever!
  9. oldiron 440
    oldiron 440
    I mix and spray with a gun, you can't beat epoxy primer and catalyzed color...
  10. arkiehotrods
    arkiehotrods
    you might check out some youtube videos on Rustoleum Turbo paint
    Roger Loupias likes this.
  11. Lone Star Mopar
    Lone Star Mopar
    I've had ok luck with the Krylon Dual paint/primer line lately.
    Splitbudaba likes this.
  12. choptop40
    choptop40
    Rustoleum self etching primer.....goooood stuff...wear appropriate breathing protection....
  13. Splitbudaba
    Splitbudaba
    CA7BB6CF-64EF-49D6-9606-6B7116764D19.jpeg F7FC06E3-65DC-45B2-8DC9-99A936CB355A.jpeg I used Rustoleum heat paint dull silver, works great, looks like glass beaded aluminum! I had a chrome fuel pump, trying not to use too much chrome. Mask it up and lightly glass beaded, I cleaned it good, remasked and sprayed with the above mentioned Rustoleum, came out great!! Paint hangs on real well! Used on my choke brackets on my carb too!
  14. gimpyshotrods
    gimpyshotrods
    The locals use this.
    https://www.montana-cans.com/
    Lone Star Mopar likes this.
  15. With zero prep!
    gimpyshotrods and blowby like this.
  16. Flathead Dave
    Flathead Dave
    from So. Cal.
    Crayola's work for me...
  17. Petejoe
    Petejoe
    from Zoar, Ohio
    Duplicolor. The engine paints only.
    Really durable.
    Elcohaulic, Deuces and rockable like this.
  18. indyjps
    indyjps
    I hate all rattle can, every time I use it is a disappointment, and the thought I shoulda mixed some paint and shot it thru a gun.
    I stopped buying rustoleum rattle can all together, the quarts are decent with acetone and enamel hardener. Flows out nice with brush or from a gun
    427 sleeper and irishsteve like this.
  19. A5C3DE3C-BF9A-4683-AF5F-9B492BC6C0A5.jpeg CB02D18A-D4BC-405C-A32D-FB3760B0C244.jpeg
    I am literally spray painting right now !!
    check out TVH brand forklift paint comes in a ton of colours is around 9-15 bucks a can depending on colour and sticks to everything !!!
    I simply pressure washed this thing last night snd started spraying this morning .
    fantastic stuff that’s super easy to use and gives great results
    here it is done 3 hours start to finish no sanding , no masking a quick n dirty clean up with a piece of card board for the edges !!!
  20. xhotrodder
    xhotrodder
    The author should be more specific in his question on spray paint. Is he talking rattle cans, if so I like Rustoleum for general household use, for car parts Eastwood. Body parts, PPG sprayed with a gun, but Eastwood also sells some good paint for body panels.
    427 sleeper likes this.
  21. Elcohaulic
    Elcohaulic
    Dupli-Color
    impala4speed and Deuces like this.
  22. CBurne7
    CBurne7
    I mean, they all get me pretty high so I really don't have a preference. o_O
  23. Your splitting hairs my friend, the definition of spray paint is any paint that comes in a sealed, pressurized container and is released in an aerosol spray when a valve button is pressed.
    This is my favorite spray paint. :D HRP
  24. catdad49
    catdad49
    Danny, do you charge them to use your name?!
  25. BamaMav
    BamaMav
    from Berry, AL
    I use whatever I find in the color I want. Walmart brand, Krylon, Rustoleum, whichever is cheapest and the right color. All about the same to me. Only time I buy the higher priced stuff is when I want something different, like a hammertone or crinkle finish.
    clem and 6sally6 like this.
  26. cfmvw
    cfmvw
    I'll bet he has a licensing agreement with them.
    hotrodjack33 and Deuces like this.
  27. Rickybop
    Rickybop
    from Michigan
    Been using Krylon.
    Getting close to painting young Zander's mini bike after doing all the upgrades. Got some Spray Max 2K clear in cans I'm gonna use over the Krylon for shine and durability.
    Blues4U likes this.
  28. anthony myrick
    anthony myrick
    Whatever’s available
    It’s all in the prep work anyway.
  29. 41 GMC K-18
    41 GMC K-18
    " Quality, knows no limitations "
    427 sleeper, Deuces and Desoto291Hemi like this.
  30. 325w
    325w
    Symore (sp). Theirs sprays great. Store upside down. Hard to find local here.
