Technical What's this supercharger part?
Discussion in 'Traditional Hot Rods' started by Fredb_, Feb 15, 2014.
  1. Fredb_
    Fredb_
    Found this among some other vintage stuff. Thanks
  2. AG F/C
    AG F/C
    I'ts a pressure switch. Probably connects the contacts at 3-5 lb boost pressure to operate an anti detonation injection (ADI) system like water or methanol or a fuel enrichment system...
    The little hose nipple connects to the manifold pressure below the blower.
  3. metlmunchr
    metlmunchr
    Looks like one of those hokey pieces of junk peddled with claims it'll give you an extra ten mpg or allow your engine to run on water, or any of a number of other lies dreamed up to separate a fool from his money.
  4. Fredb_
    Fredb_
    One of the contacts is labeled "Super Charger" the other is labeled "Ignition". I thought maybe it was a component related to racing setup or the obvious super charger. Fred
  5. AG F/C
    AG F/C
    Might be an old Judson supercharger part. definitely a pressure switch of some type. Application is probably broad.
  6. Black Panther
    Black Panther
    from SoCal
    Fred...I think that piece might be part of the electrical controls for a McCulloch supercharger..they have an electric solenoid that changes the blowers pulley diameter I believe....that makes the belt spin the unit faster...producing more boost.....
  7. el Scotto
    el Scotto
    from Tracy, CA
    That switch is on the carb linkage.
    The piece in the original post was to kick on the auxiliary electric fuel pump to kick up the go juice pressure when the carb came under boost.
  8. Cool find for sure
  9. Rusty O'Toole
    Rusty O'Toole
    Looks like a McCulloch part. As le Scotto says, it kicks in the electric fuel pump for more go juice when the supercharger pressure builds up.
  10. Dominick Hide
    Dominick Hide
    Definitely a McCulloch part. It is wired to the solenoid under the flying duck emblem on top of the supercharger. If an auxiliary electric booster pump is being used you can pig tail a wire to it. The switch is activated by vacuum not pressure, so must be connected to the intake below the carb.
  11. Fredb_
    Fredb_
    Cool. Dominick, thanks for the pick. Do you know when these were in production?
    Fred
  12. nsh57
    nsh57
    Dominick is right...Definately McCulloch, Want to sell it? PM me!
  13. Fredb_
    Fredb_
    PM sent, thanks!
