Technical What's this fan part?
Discussion in 'Traditional Hot Rods' started by Vonn Ditch, Mar 23, 2017.
  1. Vonn Ditch
    Vonn Ditch
    from LA
    This fan setup is exactly what i'm needing for an AV8 with my '40 engine. What is that hub off of the the fan is bolted to in this picture? Thanks VD fan.jpg
  2. squirrel
    not this one, but you get the idea....????
    LOU WELLS likes this.
  3. seb fontana
    seb fontana
    from ct
    Shortened generator that originally held a fan, 37-39 v-8 Ford..
    RICH B and squirrel like this.
  4. alchemy
    alchemy
    Seb's right. Remove housing, drastically shorten armature.
  5. You can take just about any 34 - 39 generator, remove the center portion (even better, just make a shortened center case piece - like 1" or so), then cut up the original armature (or make a new shaft) and now you have a fan idler. I made my own as a teen ager - about 40 years ago . . . exactly how I did it.
    In the picture shown, it appears they're using a 34 or so fan, with a home-made extension. The other approach is to find a 32 fan - which has a long extension . . . but they tend to cost hundreds of dollars - cause they're another one year only part - '32'! LOL
