Projects What's On Your Engine Stand
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, May 18, 2019.
Tags:
  1. I believe my engine stand is in hibernation, I think there is a old blue jean jacket farmers jacket hanging on it. HRP
    Hombre and Deuces like this.
  2. 19Fordy
    19Fordy
  3. RmK57
    RmK57
    Funny enough BDS still sells them for around $700.
  4. Deuces
    Deuces
    from Michigan
    Wow, no shit!!!!.... I didn't know that... :confused:
    Cool!:)
  5. earlymopar
    earlymopar
    That's going to be one sweet 270! What else are you doing to it other than the 315 heads?
    - EM
    Deuces likes this.
  6. 1965 289 bored and stroked to 308. Edelbrock Performer RPM heads. Edelbrock 7122 cam. Kieth black hyper-kinetic 10.5 flat top pistons. Edelbrock F4B intake.
    Going in my 1963.5 Falcon Ranchero
    williebill, mgtstumpy and Deuces like this.
  7. DenverFlash
    DenverFlash
    from Denver, CO
  8. RmK57
    RmK57
    Little Ranchero weighs around 2800 lbs. It should haul ass with your 308 in there. Around 350 hp ?
    Deuces likes this.
  9. 34Larry
    34Larry
    Dust.
    Deuces and mgtstumpy like this.
  10. Yes, 100 dome baby !...ha ha ha
    I'm going to run a 73-76cc head to tame them down Screenshot_20180408-173349_Google.jpg
    Deuces likes this.
  11. Never2old
    Never2old
    from so cal
  12. jimdillon
    jimdillon
    461 Booth-Arons Iron head from the early 70s. Bought it from Clyde Hensley who happens to be on American Pickers tonight, selling his EJ Potter V-8 Motorcycles. 101_2910.jpg
  13. 0.040 over 283. Got all the stuff to make it a 301 in case the 370 Pontiac in my 34 coupe blows up.
    Deuces likes this.
  14. Chrisco
    Chrisco
    from Upstate NY
  15. tubman
    tubman
    Right now, There is a 258" 8BA with a MAX-1 cam, Edmunds heads, and an old Mallory flattop. And yes, if you look close, that is a Rochester Quadrajet carburetor. They came on Chevrolet and Buick 262 ci V6's, so the size should be OK. It's a project I am currently working on. My problem now is that the Sharp 4 BBL manifold I am using has only 7 bolts holding it on. There are three in the manifold that have no match in the block, and two in the block that have no match in the manifold. It won't run for shit, and I think I have vacuum leak problems. I am having serious doubts about the quality of the Sharp manifold, and am thinking of abandoning this part of the project.
    Next up is a '51 Olds Rocket. It is a fresh rebuilt that I got cheap from a guy who didn't want it after he bought it and found out it wasn't a Small block Chevrolet. I have pulled it down enough to see that it is clean enough to be a fresh engine, and to find it has an Isky cam and Gotha adjustable rockers. I am going to remove the dual quad manifold and temporarily substitute an Offenhauser three deuce unit with the end carbs blocked of for initial start-up. Should be interesting.
    Previously, I had the '56 truck hemi on it. It was also supposed to be a fresh rebuild that was pulled from a dump truck when the clutch went bad. I lucked out again; when had it on the stand, and it would run all day at 55 lbs of oil pressure and 175 degrees. I have a car timing cover and a four BBL wet manifold for it, so I can make it sort of "Hot Rod friendly", but I think these also have heavy, sodium filled exhaust valves. I don't know if they would be a problem or not.
    And after that, I have the original 80K engine out of my '51 Ford. It ran great, but started making a funny noise a couple of years ago. I replaced it with a '51 Merc I had. When I changed the oil pans, I found a piece of what appears to be the rear main bearing thrust surface in the bottom of the Ford pan. When I get it up and apart, I am hopeful that the crank is OK and it just needs a new rear main.. If so, rings and a touch up of the valves should give me another good flathead.
    Something tells me I won't finish all of these:(.
  16. 54 Merc
    Deuces likes this.
  17. revkev6
    revkev6
    from ma
    I covet thy stash of engines....
    only stand mounted motor I have is this old guy that won't make it very long after I start her up. has cracked exhaust ports so I am going to thrash it hard with the blower. was rebuilt about 25 years ago with 30+" of weld in the oil pan rails lol.
  18. tubman
    tubman
    If it's like any of the 8BA's I had in the old days, it'll probably run forever.:D
    Deuces likes this.
  19. revkev6
    revkev6
    from ma
    I've run it for years but I have a feeling 5 psi and 5k will make an already cracked stock motor make some not so fun noises lol
    Sent from my SM-G965U using The H.A.M.B. mobile app
    Deuces likes this.
  20. OLDSMAN
    OLDSMAN
    IMG_0049.JPG IMG_0052.JPG This is the 350 Chevy engine that will go into the 42 Chevy that I'm building for my daughter
    williebill and Deuces like this.
  21. Merlin
    Merlin
    from Inman, SC
    Just picked up this standard bore 4 bolt main 350 for a future project.
    Unique Rustorations and Deuces like this.
  22. mlinton1941
    mlinton1941
    350, 202 heads, B&M gear drive, roller rockers, Marine intake (GM)
    Deuces likes this.
  23. Marty Strode
    Marty Strode
    355", 6" rods JE Pistons, Dart Iron Eagle heads, 2-1/16 Hilborn, Vertex Mag. Destined to be in my 29 RPU, soon ! IMG_6091.JPG
  24. mopacltd
    mopacltd
    Marty, you going to be street driving this? I have a big HEMI and am thinking about putting my Enderle on it.
    Deuces likes this.
  25. Marty Strode
    Marty Strode
    Dean Lowe (2).jpg That will be the race engine, I have a couple different combos for the street. Dean Lowe is the inspiration for this project.
    Speed Gems and Deuces like this.
  26. 406 SBC just came off to go into my fathers 64 Elco 20190419_142212.jpeg 20180416_133331.jpeg
    454 BBC for our drag project
    I recon no one wants to see the ol TPI 350 In the corner..
    Sent from my SM-J727T1 using The H.A.M.B. mobile app
  27. DWL
    DWL
    from Oregon
    Deuces and Unique Rustorations like this.
  28. Unique Rustorations
    Unique Rustorations
    1966 Pontiac 389 for $100. Included a set of heads too that I removed to find a single cylinder rusted and corroded due to a blown head gasket. I have since cleaned up the cylinder and it rotates now. Pulled some caps and the bearing and crank looked good. Not bad for a $100. Will pickle it and store it. That makes five (5) 389 engines now...obviously my favorite engine. Randy
    Deuces and williebill like this.
  29. [​IMG]
    not there now, it is in my 51. On stands or cradles now: one four banger from my cabriolet, a small journal 327, and a dual quad 392 semi.
  30. Seepwater
    Seepwater
    No pictures butI have
    1) Olds455
    2) Chevy 283 with tri power
    3) Chevy 350 four bolt all dressed up with Edelbrock aluminum
    4) Chevy 350 with 305 HP heads
    Hemi Joel and Deuces like this.
