whats on top of this Flathead ?
Discussion in 'The Hokey Ass Message Board' started by Mark, Apr 13, 2013.
  1. Mark
    Mark
    from CT
    supposedly a Mercury. whats the thing on top ? marine or industrial application ?
    just curious
    Thanks Fellas
  2. wino01
    wino01
    Mercury carb
  3. low merc51
    low merc51
    Mercury carb !! Kinda wierd looking arent they !!!
  4. 296 V8
    296 V8
    from Nor~Cal
    The good parts inside
  5. Mark
    Mark
    from CT
    Am i that stupid ? I guess i never saw a stock merc before.
    Thanks !
  6. carbking
    carbking
    Holley type 885-FFC as used by Mercury 1949-1951. There is a similar one used by Lincoln 1949-1951.
    Jon.
  7. Weldemup
    Weldemup
    from Central,NY
    The best part is the 4" crankshaft!
  8. R Pope
    R Pope
    Holley "teapot", AKA the Towering Inferno! somewhat prone to catching fire.....
  9. Mike51Merc
    Mike51Merc
    Thanks for the laugh. Not about you, but about the "what the heck is this?" that is everyone's reaction to that carburetor.
  10. I thought a teapot was a four barrel.
  11. pasadenahotrod
    pasadenahotrod
    from Texas
    That backdraft style 2bbl was used on various cars up into the mid-50s. In Mercs was usually replaced with standard Ford upright 2bbls with conversion plate or manifold swap.
  12. 1940merc
    1940merc
    from colorado
    1950 merc carb
  13. Ole don
    Ole don
    Save the cam, the crank, and the intake. A 265 Chev carb will bolt on that intake and make one run like gangbusters. Nobody is stupid for never having seen one, just younger than some of us.
  14. carbking
    carbking
    Not really sure why, but the laid over airhorn design was in demand in 1949.
    Mercury and Lincoln used the Holley 885-FFC.
    Oldsmobile used the infamous Rochester model AA, as well as a special adaptation of the Carter WGD.
    Prior to 1949, only a few laid over airhorn designs had been used. Here are some I remember.
    Stutz in 1931 (Stromberg)
    Packard 12 from 1931~1939 (Stromberg)
    Duesenberg J (Stromberg)
    Farmall (Zenith)
    Dodge military ambulance (Carter)
    Studebaker military (Carter)
    Also, several large trucks (Zenith and Holley).
    Studebaker had one in the mid-1950's (Stromberg).
    Jon.
  15. Mike51Merc
    Mike51Merc
    I read that the '49 redesign with lower hoods did not fit the old air cleaner, so they moved it to the side.
  16. 62rebel
    62rebel
    a Carter two-barrel will bolt up as well, because i used one off my Dodge van to crank up Dad's '53 Merc when the Holley leaked like a sieve.
    it's a cool looking setup, but not too practical for rods.
  17. bgaro
    bgaro
    well.......i just learned something too. thanks
  18. wsdad
    wsdad
    Don't throw it away. Put it on ebay. Someone (not a hot rodder) will see it as a rare treasure.
  19. dan c
    dan c
    yeah--a rochester 2-barrel is a good swap. just mount it with the fuel bowl pointing to the back and your linkage should bolt right up.
