I'm thinking hard about filling the roof on this model a I bought. Is there a good aftermarket kit for this project? What's involved with doing this and are there any tricks I need to know
there are many threads on this. Alot of people use skins from other cars or vans. It involves welding and taking your time.
You must go slow with the welding. Unless you are an accomplished welder with sheet metal you should not try it, the top may wind up FUBAR.
Go to a junk yard find a nice Chevy van or a station wagon with some nice beads in it...I used like a 90's 18 person van roof cut it off with a sawzall then flipped the back of it to the front of the sedan and just cut the excess off gave some nice beads in the roof Posted using the Full Custom H.A.M.B. App!
That's so follow the crowd like 70's-80's stuff. What's wrong with the new way,,, a soft insert? It's much easier than you think. It's also CHEEP, and it doesn't require Bondo. The Wizzard
I made several cross bars with some crown in the middle for my 30 sedan and the used a flat peice of 20 gauge and worked it out from the center moving back. All the donor roofs that I could find had ribs in them which is a look that I don't care for.
Look at AMC Eagle wagons. Also if there is a van conversion shop in your area where they put raised roofs on full size vans you may get a roof cut off for free. Nick
I'm with Phoenix5x on going with a van roof for a filler. I like the way the ribs break up the span, and used a late 80's Chevy conversion van roof with ribs that were up,not indented.If you cut the roof off and flip it around (front to back) the curve on the back of the sedan fits really well.I also ended up with about 4 ft. of extra roof material, and cut the ends of the ribs off that and welded them to the front of the new sedan roof to blend it all in over the visor. Send me an e-mail address, and I'll send you pictures (anyone who's interested).I dragged my feet about chopping and filling, but what a difference! 3" chop. Good luck! Mike from Mass.
I am from the school of thought that the original soft tops are correct in appearance and are as traditional as the day is long. It's not that hard to do and IMHO the filled,ribbed tops remind me of the 80's slick look,,but that's just me. HRP
I should have also said if you can drive a Tack hammer and read a tape measure you can do a stock type insert at home yourself. The Wizzard
See I like it both ways. The cloth top looks great but so does a we done filled roof I'm not down with the ribs tho it has a Boyd, little jon look while they built great stuff I'm not a billet guy. I don't have the gas welding skill to do it but I can swing a tack hammer like a tweaker on a three day buzz
I'm with the guys who like the soft top look and I'm also with the guys who like a steel roof filled top. Advantages of the soft top: It looks like the car was built originally, classy and traditional. Advantages to the steel filled top: It makes the body stroger structurally by a huge amount and provides a low maintenance leak free roof. What I would do would be a combination of both. Strong, good looking and traditional in appearance as well. Not to mention a little sneaky How ? Instead of putting in the usual wood and chicken wire that the soft top usually uses, install some metal ribs as supports and then weld roof metal into the top opening leaving the original recess for the tack strip that finishes the soft top insert. After that you can have the top covered with soft insert fabric and install the tack strip. The results: A structurally solid and leak free roof with the traditional old soft top look. A win win in my eyes.
Here's the thread showing how I filled my '28 Tudor roof: http://www.jalopyjournal.com/forum/showthread.php?t=636247 I'm planning to cover it with vinyl so I'll have the best of both worlds.
If you can get a copy of Hot Rod Deluxe magazine, July 2013, Roy Fjasted from West Coast Street Rods, welds an insert in a Deuce sedan. If you can't find it PM me and I'll send it to you. Model A and Deuce are very close in dimensions.
I vote with the "soft top" crowd here. I have no issues with mine. It has been through several heavy rains on the road and survived 120 mph passes at the H.A.M.B. Drags.
I guess you also missed the purpose of a discussion forum, to get info and share ideas. Lots of info provided and some alternate ways to approach something never hurts.
Does this look ok for those of you that have done it? It is just setting on there, still have to start welding. Posted using the Full Custom H.A.M.B. App!
