Hot Rods What Will My Displacement Be?
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Jun 23, 2020.
  1. Fortunateson
    Fortunateson
    As the title states that's my question. Starting off with a 255 ci Mercury and will be adding .060 overbore. I'm thinking 265ci?
    Thanks!
  2. saltracer219
    saltracer219
    Bore x bore x .7854 x stroke x the number of cylinders = displacement in cubic inches
  3. Bandit Billy
    Bandit Billy
    I was going to say the unconscious transfer of an intense emotion from its original object to another one,
    Saltracer was likely more accurate though.
    GordonC, pitman and 41rodderz like this.
  4. Penetrator
    Penetrator
    from SK CAN
    Yes.
  5. It is really simple math as Saltracer219 explained.:confused: I don't know how to do it but apparently he does.:rolleyes:
    lothiandon1940 likes this.
  6. AngleDrive
    AngleDrive
    from Florida
    Bigger than it was
  7. 1971BB427
    1971BB427
    from Oregon
    Probably closer to 263c.i.
  8. squirrel
    265 almost exactly, according to my calculator. But I could be wrong.
  9. pitman
    pitman
    Pies aren't square...
    And "thinner than a tin gasket."
    (to bump up the ratio)
  10. Fortunateson
    Fortunateson
    Well, using the formula given I got 264.6971237797227ci so I'll stay with my original mental estimate of 265ci. I guess all those years of teaching Math paid off!
  11. squirrel
    I used pi/4 instead of .7854, so I got a slightly higher number...265.05something.
  12. saltracer219
    saltracer219
    I am not saying that this is etched in stone, but it is the formula that the S.C.T.A. and the F.I.A. have used to determine displacement for many years. I always figured if it is accurate enough for them, I will roll with it!
  13. Fortunateson
    Fortunateson
    I'm picking up my C8BA, that was originally assembled with Mercury components, tomorrow after an initial cleanup bore. Final will be .060 over. I picked up my re-ground cam yesterday with a M70 grind similar to an Isky Max1. They reground it for $225 CDN which would be around $160US.
    Waiting to order my bearings, pistons, etc. as the border is closed right now so I wouldn't be able to pick them up until it reopens. Local parts house said they could get me Scat pistons for between $1800-1900! I called a place I've used before where I got pistons for my 292 Y block for $98 US and they'll get me pistons for the flathead for $199US which is a wee bit better than the Scat stuff...
  14. jimmy six
    jimmy six
    Kinda like all the 301 Chevrolet’s we built out of 283’s.... But when GM did it somehow it was a 302.
  15. squirrel
    Oh, the formula is fine. It's not exact, but it's definitely close enough.
  16. Speed Gems
    Speed Gems
    Figure .005 equals about 1 cubic inch so .030 is 5 cubic inches, .060 is 10 cubic inches etc.
    That's because if you do the math it comes out to 301.59 so instead of coping all those uneducated (Non engineering type) Hot Roders:rolleyes: they bumped it up to 302.
    Deuces likes this.
  17. Deuces
    Deuces
    Yep! 302 it is.....
  18. squirrel
    I like the story I made up that they were a .120" over bored 283, instead of 4.000" bore, and that actually gives you 301 CI.
    But I wasn't around back then, and don't know what the actual piston and bore size was.
  19. 51504bat
    51504bat
    Back in the late '60's when I was in HS if you had a 301 Chevy you were hot stuff.
    jimmy six, X-cpe and j3harleys like this.
  20. gene-koning
    gene-koning
    Back when I was in high school, if you talked the right game, everything could be hot stuff. If you could back it up You were indeed hot stuff.
    I had a buddy that bought a late 60s Nova with a small block with a 3 speed on the floor. To hear him tell the story, it was some hot stuff. All I had to drive around was daddy's 4 door Oldsmobile. With 4 guys in the car, daddy's Olds would put a whooping on my buddy's Nova anytime we lined up. I guess the 394 4 bbl was more hot stuff then the "special" mix of small block Chevy in the Nova. Then a couple years out of HS, my Nova buddy traded in the Nova on a brand new 76 Camaro with a "supped up" motor (he probably put some Accel plugs in it, that would have been at the limit of his automotive knowledge). At that time I was driving my future wife's Sport Satelite with a 383 and it whopped his new small block Chevy every time, without much effort. I don't think the cam, 780 Holley, and the 391 sure grip rear end made much difference.... It wasn't until we did a double date and used the Satelite before he understood something other then a small block Chevy could be fast too. Gene
    King ford and hemihotrod66 like this.
  21. DemonTweaks
    DemonTweaks
    from T-Town, WA
    The simplest for V8's is:
    Bore x Bore x Stroke x 6.283 = Cubic Inches.
    Example:
    4.125 x4.125 x 4.000 x 6.283 = 427.636. (And using standard math to round it to closest full number gives 428. So all Chevy guys are driving around 'Ford' 428's! )
  22. squirrel
    My Chevy 427 is .040" over so it's a 435, but if it were standard bore and stroke, it would be 4.250" x 4.250" x 3.76" x 6.283 = 426.71 cu in which rounds up to 427
    not sure what you're on about? :)
  23. DemonTweaks
    DemonTweaks
    from T-Town, WA
    All the LS fan boys (and most people stroking small blocks) say their 428's are 427's since the Z-06 Corvette made the same calculation error.
  24. squirrel
    oh...this is a traditional forum, so we only talk about real 427s. not that late model crap.
    ottoman, Just Gary and DemonTweaks like this.
  25. indyjps
    indyjps
    .030 over 255 Merc
  26. jimmy six
    jimmy six
    Not to long ago I built a “stroker” SBC. Started with a cherry 1967 283 block. Bought a forged light 1/4” arm from SCAT while they had them. . . It was a great running 307.
    DemonTweaks likes this.
  27. jnaki
    jnaki
    Hello,
    We have known a friend from our high school days. His 1956 Chevy Bel Air hardtop was one fine hot rod and racer. It was a daily driver with his stock 265 that was replaced with a newer 283. Then all of a sudden, it sounded a lot better and was faster. The 56 Chevy now supported a 1/8th over bore and he now had a 301 c.i. for his challenges and cruising. He ran with that new set up for a while and then one day a rumor started by everyone that knew him. He had installed a custom Reath Automotive ½ inch stroked crankshaft and new accessories, now was rumored to have a 352 cubic inches.
    It was very fast and he would not deny or confirm the rumors. The 56 Chevy had no takers at any time during this time period. (Except me and my Impala.) Against a bored and stroked 352 cubic inch Chevy? What was I thinking? (Stories in the HAMB threads)
    56 Chevy at Lions Dragstrip
    Jnaki
    So, an 1/8th over bore is 301. Add in a ½ inch Stroker kit crankshaft and it is now 352 cubic inches. That was the way it was in So Cal. Lots of 1/8th over 283 motors for a fast, but reliable motor for everyday use and races at those times on the street. But, hardly anyone ran a 352 cubic inch motor for everyday use and then raced on Friday/Saturday nights with regularity. There was a thing about being huge and fast, but not as reliable as just a 301.
    Jump up many years after we were married and living in the OC. Our young couple neighbors drove up in a dark green z-28 Chevy. The first thing we said was…wow! The rumble, the look and when he took me for a drive, so much power going down Coast Highway in all 4 gears. Positraction plus 4:11 gears and it was a strong contender for many stock car wins without any other modifications. This was a factory hot rod and a neck snapper through the gears. What did he have for a motor? A factory listed “302” cubic inches.
  28. Boneyard51
    Boneyard51
    I always figured cubic inches the old fashioned way I was taught in school back in the fifties. Back when 2+2 =4! Lol Pie are square! ( Pi x R squared). You take the radius ( 1/2 diameter) and square it (the number times itself) then you multiply times pi . What you use for Pi depends on how far you carry the decimal point, but I usually use 3.1416. Then you multiply by the stroke and then times the number of cylinders. That’s the way I was taught in math, back in the previous century. I use this, mainly because I can remember it! Lol
    Bones
    squirrel and jaw22w like this.
  29. jaw22w
    jaw22w
    from Indiana
    Boneyard51 likes this.
